Question about Greenlee 7646 Hydraulic Punch Driver
How do you add hyd oil to hand pump and bleed air out?
  • frank lectricman
    frank lectricman Feb 11, 2014
    Hi fec10, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • frank lectricman
    have a greenlee 767 hand hyd pump oil leak at swivel need to refill
Have a767 handpump had a leaky swivel joint and oil leaked out need to refill
Posted on Feb 11, 2014
  • frank lectricman
    have a 767 hyd handpump with a leaky swivel nedd to refill with oil
  • frank lectricman
    pump unscrews behind relief valve
2004 LZ27KC604 Wen pushing levers to go forward, machine jumps and lurches
Sounds like you have air in the hyd. lines You need to bleed the air out. You can raise the back wheels off the ground and open the valve on the hyd drive motor just enough to let the air out and run the machine for a half hour on low speed and another half hour on high speed and it should correct the problem. You need to do this on each motor or wheel. Be sure you have the correct weight oil in the unit as well. Hope this helps.
May 26, 2016 | Garden
4496 CASE TRACTOR .Ran out of hydraulic oil , filled up and bleed lines , still have no steering and the brake is out ,.What valve is locked in ?
by bleeding lines where exactly did u do this ? , the place id try 1st is right off the pump to the dist block (carefully!!!) if no pressure there then a more aggressive repurdge of hyd sys is needed using another machines hyd system connected to remotes inputs off the dist block
reason 4 this is that hyd oil pumps don't just pick up oil again when run dry an have to be helped to pressure up again , Also another possible cause is that pressure relief is stuck open , this doesn't allow any pressure to build up
Nov 13, 2015 | Cars & Trucks
Replaced power steering pump,trying to bleed system but steering wheel wont turn what do I do?
No bleeding fill with oil start the car add some oil if the pump good the air will come out
Mar 14, 2015 | Cars & Trucks
7FGCU45BCS TOYATO FORK WHY ARE LIFT CYLINDERS SLOW PUT NEW HYD. PUMP AN CONTROL VALVE ON ALSO CHANGED FLUID AND FILTERS COULD THERE BE AIR IN SYSTEM?
air bleeds out with the piston movement so with the piston movement air is put in and then is evacuated as the piston come back down. an indication of air is a jerking motion of the rams as pressure is built up and the ram moves which lowers the pressure until it gets up again. I would be having the pressure relief valve on the pump checked for correct setting. I would also be having the hydraulic hoses checked as they have been known to fail internally and block of the oil flow.
Aug 12, 2014 | Cars & Trucks
Taylor fork lift
If your old pump was knackered then I would change your return and suction filters, the insides of the old pump will be choking them. Also check your suction hose (make sure its tight). When the pump was fitted did the engineer readjust the relief valve on the control valve? Is your hyd oil level ok if not top it up it could be drawing air. Your hyd system could also be air locked aswell so it may be a good idea to bleed the system.
Aug 19, 2013 | Heavy Machinery
I just put oil on my cherrypickers manual hyd ad dosent pump what can i do?
sounds like it has a gut full of air which can be compressed whereas hyd oil cannot and is not circulating. must be some way of bleeding system
Dec 10, 2012 | Cars & Trucks
1988 camaro 5sp manual, after replacing the master cylinder, bleeding was success, it was only taking 3 months to learn how to bleed it out. Now, when i'm playing burnout, I've lost my pressure on the...
The easiest way to bleed out a clutch hyd system is to connect a hose from the closest front brake caliper bleeder to the bleeder on the slave cylinder. Crack both bleeders open and pump the BRAKE pedal very slowly. It might be best to have someone pump the pedal for you.You will feel the pedal get harder once all the air is pushed out of the clutch system. Close off bleeders and remove hose and test drive car.
This is a back bleed and it's the only way to get all the air out of the clutch system on Peugeots and some other Euro cars.
Feb 28, 2010 | 1988 Chevrolet Camaro
1994 chevy 3500 1 ton dump hyd problem when I activate the hyd unit, I can hear the pump running, and it seems to develope a load on the motor, but the cylinder does not lift. I had the dump body...
There should be a bleeder valve on the cylinder itself somewhere. Otherwise with air in the system, Im surprised no hyd fluid came out the top of the cylinder!
Feb 05, 2010 | 1994 Chevrolet C/K 3500
Greenlee 7646 Hydraulic Punch Driver Logo
959 people viewed this question
Top Greenlee Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Greenlee Home Fencing Expert? Answer questions, earn points and help others
