Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
My freezer has started to frost over. It started about 2 weeks ago and is getting worse. What is the cause for the automatic defroster to stop working.
  • Jenn-Air Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 15, 2010
Permanent ice on back side of fridge near the sensor (thermistor?)
Hello Paola! If your refrigerator is frost free, that is an indication the ice build up is caused by a failure for your defrost circuit. This circuit is made up of a defrost heater, defrost thermostat (both in freezer section behind the inner shield) and either a defrost timer (if your unit is older than 5 years) or the control board if younger. If you take off the shield in the freezer and the evaporator coil is coated in ice that is probably the cause. To check, defrost the unit by unplugging, and then use a hair dryer or heat gun to defrost all the ice off. NOTE: Be ready to deal with the massive amount of water from this defrost or you will have a mess. IF I am right, the refrigerator will start working normally for 2-3 weeks (depending on your humidity it could be shorter). Then you will get another ice build up and it will do the same thing.
Jan 16, 2012 | Refrigerators
FRS26KR4CB1 side by side refridgerator
Hi MDstuff,
Stopped cooling.  Check the backl of the freezer to see if the Coils are Frosted completely.  The buzzing sound could be the frost touching the  Fan in the back of the freezer behind the cover. Sounds like your Defrost heater has gone south.
1. unplug the Freezer, power down.. for safety
2. Clean all the food out of your Freezer,
3. Remove the shelves and Ice maker tray stuff.
4. REmove the panel in the back of your freezer
5. Is the Coil(Evaporator, Radiator)you see  frosted up?
6. At the bottom of this coil. you should see a metal assembly that stretches accros the bottom of the coil with a wire connection on both ends. This is the Defrost heater.
Remove the heater and look to see if the heaterspring inside the glass tube is broken.  If so, get a new one from Ebay, or www.repairclinic.com.
In the mean time while your waiting on a part, Use a hair dryer to get rid of all the frost and put your freezer back topgether.  You sahoul get 2 or 3 weeks of service on your Freezer, before it happens again.
Oct 13, 2007 | Refrigerators
Freezer is forming frost around the light fixture located in the ceiling of the freezer compartment. We must manually remove the frost approximately two times per week.
If you are certain that the evaporator fan is running then your automatic defrost function has stopped working.
There are 3 things that cause it to stop working:
1. The defrost control
Item 801 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5206998&diagram_id=26604625#d26604625
2 The defrost heater
Item 826 above link
3. The thermo disc Item 621 above link.
4. The bi-metal thermostat (closed below 60 deg F)
Item 4 can be tested for continuity at temps below 60 deg F.
Item 2 and 3 can be tested at room temp for continuity.
Item 1 the main board controls the defrost cycle which turns the defrost heater on and off.
Primary suspects would be the defrost heater and thermo disc.
Shop areound for the heater if you find that is bad... the link I posted that heater seems VERY expensive to me. The heater PN: WR50X10042 I note prices in the range of $115.00 - $171.00
This PN defrost heater has a history of repeated failure.
Thanks for choosing FixYa,
Kelly
Sep 08, 2011 | GE Profile PFS22SBSS Bottom Freezer French...
My freezer keeps getting frost in the back. When this happens, all the temps in my feezer and fridge go up. Fridge is at about 45 and freezer is at 4. This is the second time in three weeks. What should I...
some component of the automatic defrost system is defective watch this video :::pay special attention to the part about the defrost thermostat since itthe most likely cause with frost built up in the freezer the defrost t-stat should have continunity (the circuit to it should be closed)
here is the link for the video,copy and paste it into your browser if it doesnt link automatically.....http://youtu.be/TnRKj7_BtNw
Jul 20, 2011 | GE Profile Arctica Stainless Steel Top...
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Frosts up wont get cold MCBR1000S
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Magic Chef CTB1821AR Top Freezer...
My Norcold DE0051 I have to keep defrosting every 2 weeks
Occasional defrosting is needed on these units. 2 weeks isn't that bad considering the environment that it is in (your boat). Every time that you open the door, moist air enters the fridge, and the moisture eventually collects on the freezer plate, and freezes. Putting foods into the freezer that are uncovered also contribute to this a great deal, as do putting in warm / hot foods before giving chance to cool down.
These freezers do not have automatic defrosters. The target environment typically has limited power available. Automatic defrosters would easily double the power requirements.
You can also check the door seals on your fridge as well. If they are not sealing properly, they can also let in humid air which then causes moisture to collect on freezer plate.
Aug 10, 2009 | Thetford Norcold DE0051 Refrigerator
Fridge part is not cooling; freezer is frosting up
your ref. has a defrost problem.you will need to take back panel off inside freezer and take your hair dryer again and defrost the system.then you can check your heater,thermostat which is located at top of coils that were defrosted.sometimes the thermostat will pop and not allow it to go into defrost and you need to check defrost timer.
Mar 12, 2009 | Refrigerators
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
