Question about Bosch Dishwashers
Bosch model # SHU3032UC The timer stops at halfway trough the rinse cycle, and the water continues to rinse until I push forward a bit the timer. Should I change the timer ? Thanks Léo
  • 901 Answers
If it is a mechanical timer you can clean and try. If you prefer to replace note down the wire colors and do the change.
Posted on Sep 15, 2010
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
GE dishwasher won't drain or cycle
TRY TO UNPLUG THE UNIT FOR AN HOUR TO RESET THE ONLOAD SETTING THAT PROGRAMMED INTO IT..
KEEP ME UPDATED
Sep 28, 2008 | Dishwashers
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
Cycle won't advance out of initial draining mode
There could be many reasons, but the 2 most possible would be :-
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 26, 2009 | Bosch 24 in. SHV4303 Built-in Dishwasher
Bosch dishwasher shu3032uc-14 doesn't clean very well tried different things but no help sometimes i can catch top spinner not working all the holes are clean where is the water level supposed to be and...
Pour a gallon of white vinegar in bottom run halfway thru wash cycle turn off let unit sit overnight to properly soak-then run a couple of times to rinse out vinegar(vinegar dissolves calcium which causes unit to not function properly) also check unit inlet for contaminates and clean as neccesary install inline filter if not one there..(the hot water tank will tell if you have a calcium problem(hard water problem)shut off unit undo relief valve on tank hook up hose to bottom then drain check for white chunks),calcium wreaks havoc on all household appliances and shortens there lifespan!!! :)
Jul 05, 2009 | Dishwashers
Dishwasher stalls
Water-heating cycle
Timer
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
May 31, 2009 | Bosch SHU4006 Dishwasher
Bosch SHX46A02Uc/21
it is likely a control module issue. I will take mine apart this weekend to verify what others have said: solder joint on circuitboard burns out from possible overheating, and DW doesnt go into rinse cycle. Try rinse and hold cycle to see if it stops on its own. mine does, but the other cycles which require the rinse to go to 156 degrees do not; the continue to run until I cancel and drain.
Feb 01, 2009 | Dishwashers
Cycle stops, won't drain
This is either a bad timer or a bad heat sensor. On most cycles that call for the water to be heated it will pause the timer and continue washing/heating until the sensor is satisfied the water is hot enough. Try selecting a quick, delicate, or china cycle without heated rinse or dry. If it works this way the timer is fine but the sensor is bad. Sometimes cold water to the machine will cause this problem because the machine is not capable of totallly heating cold water. It is only designed to boost the temp. Make sure you run hot water at the sink before you start the machine.
Jul 03, 2008 | GE Nautilus 24" Built-in Dishwasher
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwaser is stuck in Rinse/Dry cycle
It could be a sensor or timer solenoid in the dishwasher maybe broken and needs replacing.
http://www.repairclinic.com/bosch-dishwasher-parts-gg.htm
Apr 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
406 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
