Question about Zebra Z4Mplus Label Printer
Printing shifting backward
The label impression is shifting backwards during printing.
sachin kalia
bayer material science ltd
greater nodia (u.p)
  • 300 Answers
You probably need to clean the sensors, turn the printer off open the side cover, lift the printhead and you'll see the sensors. Clean them with a damp cotton bud.
Posted on May 17, 2008
Why is Crow's head backwards when watching the movies?
This is one of the most prevalent issues for viewers of the show. The fact is that Crow's head is not backwards. However, because of the shape of his head there is a 3D optical illusion that can make some viewers see him as backwards and some as forward.
Sep 04, 2016 | Mystery Science Theater 3000 (1988)
My machine is showing me p-22 what does it mine
Color regist adjust failure
• The color shift amount is greater than the specified
range during main scan direction registration correction.
range during sub scan direction registration correction.
• On the color shift test pattern, the maximum and minimum
deviations detected in the main and sub scan
directions go over the predetermined value.
Dec 23, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Zebra LP2844 pulls labels in before printing
Yes, first of all, it is necessary that the labels are pulled backward (other wise you could not print on the upper part of the label). It appears from time to time that it is a problem - generated by the label itself. Try to use a different label (of size and material) to see if the behavior changes ...
Good luck.
Apr 16, 2013 | Zebra LP 2844 Thermal Label Printer
What is a goalkeeper glove?
Goalkeeper glove is designed protectors to prevent the fingers from bending backwards, and has segmentation to allow greater flexibility. Moreover, the palms made of materials designed to protect the hand and to enhance a player's grip.
Feb 06, 2013 | Clothing Accessories
Why is my DYMO QX50 printing backwards?
Hit the Function button and browse through the settings, I believe most of the DYMO labelers have a "MIRROR" function...turn that off and it should print out right.
Mar 29, 2011 | Dymo LetraTag QX50 Thermal Label Printer
The barcode cannot be printed on the direct label
Your description is not very specific but no printing can be the result of:
1. The darkness is not set high enough
2. The ribbon is loaded backwards
3. You are trying to do direct thermal printing (no ribbon) but the label stock is not direct thermal stock.
Maybe you can provide more details.
Hope this helps,
Jul 18, 2010 | Zebra Stripe S600 Thermal Label Printer
My Z4M Plus printer is not printing the label all the settings are fine no error. The ribbion shows the image but it doesnot print on the Label.
Two possiblities: 1. the darkness is not high enough for the ribbon/label combination. 2. the ribbon is on backwards. if the ribbon is on backwards, you will still see an impression on the ribbon but not on the label. This means all the ink transferred to the printhead which should then be cleaned.
The ink side of the ribbon needs to face down to the label to print so the easiest way to make sure which side has the ink is to use a label or piece of tape and touch it to the ribbon. If no ink comes up in the adhesive then that is the wrong side.
Hope that helps !
Apr 01, 2010 | Zebra Z4Mplus Label Printer
I put the battary in backward, runs less than a min now and cut off
the only thing that would be harmed is the battery. as for the code 4 go to a honda dealer and ask the service manger what a code 4 is!
May 02, 2009 | 1985 Honda GL 1200 Ltd. Ed. - SE-i Gold...
Backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Dec 31, 2008 | Singer 3116 Simple
Zebra Z4Mplus Label Printer Logo
155 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
