Question about Goldstar MV-1525 1000 Watts Microwave Oven
Pressed the start button ....made a humming sound and just died as in no power at all?
  • Goldstar Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 15, 2010
Microwave has power will not start
When you say it just hums, do you mean that it sounds like it is running but isn't heating? Or do you mean that the sound is different from when it normally runs? Is it quieter or noisier than normal? Do you hear the fan running or is that sound missing?
IF it sounds normal (or about the same as when it worked), but it's nust not heating, then it is probably a bad magnetron tube.
Aug 18, 2014 | Whirlpool Microwave Ovens
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
My Sharp Carosel volume got really quiet. Is there an easy fix?
If you are referring to the beep when you press any function,the beeper on the board may have failed.
The two other sounds are :i. there is a fan that comes on when start is pressed and, ii. the other sound is a heavy hum also when start is pressed.This comes from the transformer and maybe the magnetron tube. If you are not getting these sounds then troubleshoot these areas,careful though, the output voltage from the transformer is about 1.5kv
Mar 02, 2014 | Sharp R-1480 Microwave Oven
My LG LRMP1270ST microwave oven stopped working in the morning. It just flat died when I put 2:00 minutes on the timer and pressed start I heard the pop/breaking sound. So immediately I stopped the...
The main fuse has blown in the microwave, you also have secondary problem that sounds like the magnetron has failed, but there are two other parts to consider, the high voltage capacitor and diode work in conjunction with the magnetron to heat the food. The repairs could run as high as a new microwave oven.
Feb 14, 2011 | LG Microwave Ovens
My microwave kenmore 66222500 makes a humming sound like if it was on when the door is closed. i have to unplugged it or leave door open to stop the humming sound. I tested the magnetron, the primary and...
Possibly a shorted relay on the main timer board?? hum coming from transformer being powered with no fan running. With No fan you can hear it hum. shorted power relay on main board.
Jul 28, 2017 | Kenmore 68361 Microwave Oven
How do I adjust the power levelthen start the
Press "Power" until you get to the level you want. Then enter the # of minutes on the keypad (CANNOT use express cook times.) An alternating runnig hum will let you know the setting is working.
Nov 08, 2009 | Hotpoint RVM1635 Microwave Oven
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
