Question about Amana NAV8805E Top Load Washer
Amana nav8805eww. washer. starts, runs a few seconds, stops and flashes all indicator lights around the selector twice. sits for a few minutes and flashes twice. continues this for ever. had a power outage last night also.
5 Suggested Answers
  • 185 Answers
SOURCE: my amana washer top load
check the motor coupler
Posted on Mar 26, 2008
Illeagle
  • 525 Answers
SOURCE: smoking washer Amana NAV8800AWW
Ok, that's a different scenario. Generally, when a washer is agitating and develops an overload that stalls or overheats the motor, the problem could be caused by:
1. Too many clothes for the amount of water level selected. If clothes don't have enough water to circulate in properly, it can put excess pressure on the agitator which transfers to the gearcase, drive belt, and finally the motor. The motor is thermally protected and stops running until it cools down, then it will try to restart. In the process the drive belt could burn slightly to completely,so you may want to inspect the drive belt for burned areas.
2. Transmission malfunction, where something inside the transmission breaks due to an overload and jams a gear. End results can be the same as above.
I suspect a clothes overload may have caused the problem and once the overload is alleviated, the washer should operate normlly if the belt didn't burn,
Posted on May 27, 2008
SOURCE: Amana Touchmatic Heavy Duty Washer Filter Light Flashing
I have the same washer unit and I purchased my washer new in 1989. The flashing filter light is normal. If the light doesn't flash, than the water filter is plugged up. The water filter is self cleaning each time the water empties. You can take off the front panel(two screws at the bottom and the top disengages with metal clips. The water filter in at the bottom on the right, white plastic housing. There is a drive belt from the motor that powers the pump. When the washer goes into the spin cycle, the motor changes rotation direction and the pump works in reverse, thus flushing out the lint that may have been captured during the agitation cycle. I hope this helps.
Posted on Jun 23, 2009
  • 2699 Answers
SOURCE: I have a amana mod#nav8805eww it will spin but
it's the timer or the capacitor,most likely it will be the timer,i've very rarely seen the caps go bad
Posted on Feb 11, 2010
How to get alarm to stop blinking after replacing water filter
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
Dec 03, 2015 | Fagor FQ9925XUS
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
    May 04, 2012 | 1994 Nissan Maxima
    1994 Honda Accord 4 Speed Automatic - Car will not start after being driven for 10-25 minutes. If car sits for 10-15 minutes or sometimes longer car will then start. Car has also died at a stop light and...
    Sounds like your catalic converter is trying to stop up. When you drive it this heats up and causes your car to vapor lock and quit running you let cool down and it will start back and run for a while. You can take it to a muffler shop and they will check it for free. This could be any number of issues but this is where i would start.Best of luck to you, Thank's for using Fix Ya.
    Apr 19, 2011 | 1994 Honda Accord
    Tv desn't turn on,power light just flashes ten times and then stops and then again
    Error Indication Information
    Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
    (Note 3) (Note 4)
    POWER LED TEMP LED
    Note:
    1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
    2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
    change to another every 5 seconds in turn.
    3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
    or accumulated operation time of the Air Filter reaches 400 hours.
    4.LAMP OFF: The LED will flash right after the Lamp goes off.
    5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
    6.IC6001 is mounted on TV Main C.B.A.
    Clogged air filter
    more than 90%
    15)
    16)
    17)
    18)
    1)
    2)
    3)
    4)
    5)
    6)
    7)
    11)
    8)
    9)
    10)
    12)
    13)
    14)
    - flashes 5 times -
    every 5 seconds
    IC2301(pin82) detects the clogged air filter, then indicates the
    error when the air filter is clogged 90%.
    Front Fan stop or
    Lamp Fan stop
    flashes orange
    once every
    5 seconds
    IC2301(pin12) detects the Front FAN stop or Lamp
    FAN stop, then indicates the error when the Front FAN
    or Lamp FAN is stopped.
    Lamp Cover open
    Temperature Sensor
    short or open
    flashes orange
    twice every
    5 seconds
    flashes orange
    3 times every
    5 seconds
    flashes green for
    140 seconds.
    flashing red for
    60 seconds.
    light up red.
    flashes once
    every 5 seconds
    flashes once
    every 5 seconds
    flashes red for
    10 minutes
    flashes once
    every 5 seconds
    Abnormal
    Temperature
    flashes twice
    every 5 seconds
    flashes twice
    every 5 seconds
    Request for Lamp
    Replacement - - lights up
    Power Ballast Error
    (abnormal
    Lamp voltage)
    flashes 3 times
    every 5 seconds
    Power Ballast Error
    (abnormal
    temperature)
    flashes 4 times
    every 5 seconds
    Power Ballast Error
    (other causes) - -
    Request for Filter
    Cleaning -
    Abnormal Voltage
    on 16 V line of
    LCD Main C.B.A.
    flashes twice
    every 5 seconds
    flashes twice
    every 5 seconds
    Abnormal Voltage
    on 14 V line of
    LCD Main C.B.A.
    flashes 3 times
    every 5 seconds
    flashes 3 times
    every 5 seconds
    Abnormal Voltage
    on 7 V line of
    LCD Main C.B.A.
    flashes 4 times
    every 5 seconds
    flashes 4 times
    every 5 seconds
    IC2301(pin76) detects the Lamp Cover Unit condition
    (open or close), then indicates the error when the
    Lamp Cover Unit is open.
    IC6001(pin85) detects the Duct FAN stop, then
    indicates the error when the Duct FAN is stopped.
    IC2301(pin74 and 75) detects open or short of the Temperature
    Sensor (R2911) on Front Thermistor C.B.A., then indicates the
    error when Temperature Sensor is open or shorted.
    (The error is not detected for 1 minute after Lamp ON.)
    IC2301(pin74 and 75) detects the temperature attached near
    the Front FAN by the Temperature Sensor (R2911) on Front
    Thermistor C.B.A., then indicates the error when the
    temperature becomes more than 43 C (109 F).
    IC6001(pin86 and 87) detects open or short of the
    Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
    then indicates the error when Temperature Sensor is open or
    shorted.
    (The error is not detected for 4 minutes after Lamp ON.)
    the Lamp by the Temperature Sensor (R2901) on Lamp
    temperature becomes more than 60 C (140 F).
    IC2301(pin11) detects the error of LCD Power C.B.A.,
    then indicates the error when the temperature fuse
    (117 C)(243 F) in LCD Power C.B.A. is open.
    IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
    then indicates the error when an inner malfunction of LCD Power
    C.B.A. occurs, the Lamp voltage becomes more than 130V or
    less than 30V, Lamp current becomes more than 5A, or the Lamp
    is cracked.
    IC2301(pin11) detects the error of the Lamp, then indicates the
    error when the Lamp is short-circuit.
    IC2301(pin48) detects +16V line voltage on LCD Main
    C.B.A., then indicates the error when the voltage
    becomes less than +13V.
    IC2301(pin47) detects +14V line voltage on LCD Main
    becomes less than +11V.
    IC2301(pin45) detects +7V line voltage on LCD Main
    becomes less than +5.7V.
    IC2301(pin44) detects +3.3V line voltage on LCD Main
    becomes less than +2.5V.
    flashes 3 times
    every 5 seconds
    flashes 4 times
    every 5 seconds
    Abnormal Voltage
    on 3.3 V line of
    LCD Main C.B.A.
    - flashes 5 times
    every 5 seconds
    Forced cooling
    The failure of Lamp
    light up
    Temperature Sensor
    short or open
    Abnormal
    Temperature
    Duct Fan stop -
    When accumulated operation time of the the Lamp reaches
    5000 hours, OSD (replacing the Lamp) appears on the screen.
    Note: The Lamp time is stored in EEPROM (IC2305).
    When accumulated operation time of the Air Filter reaches 400
    hours, OSD (cleaning the Air Filter) appears on the screen.
    Note: The Filter time is stored in EEPROM (IC2305).
    During forced cooling, this indication is indicated.
    IC2301 (pin11) detects the failure of light up processing of
    the Lamp, then the POWER LED is changed as follows.
    1) POWER LED flashes green for 140 seconds (while turning on).
    2) POWER LED flashes red for 60 seconds (while cooling).
    3) POWER LED lights up red (standby).
    Note: If the Lamp will not light after attempting turning on the
    power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
    LCD Main C.B.A. may be defective.
    Error Symptom Problem Possible Solutio
    May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
    Icemaking cycle automaticall self stops and cleaning light blinks
    ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
    Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
    Washer starts, runs a few seconds and stops,does it over and over
    Sound like the internal overload on the motor may be going out .Thsi is usuaklly due to bad or worn bearings. If you know anything abotu electricity,take a voltage reading at the motor whe it is in the run cycle(when it stops) If you stil have have the 110Volts to the motor then the motor is bad and need to be replaced.If you do not then you wil have to look elsewhere for the problem.
    Dec 14, 2008 | Amana NAV5800A Top Load Washer
    Front Load Washer - Error F30
    hI I HAVE REMOVE THE TOP COVER. YOU WILL SEE AT LEFT A PLASTIC ACTUATOR WHO MUST BE UNPLUG FROM ANOTHER PLASTIC PIN. JUST PUT IT BACK TOGETHER AND THE PROBLEM WAS GONE!
    Jun 16, 2008 | Washing Machines
    Amana Model NPW5400TQ0 Washer
    REPLACE THE TIMER OR Power control BOARD
    Jan 30, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
    Amana NAV8805E Top Load Washer Logo
    77 people viewed this question
    Top Amana Washing Machines Experts
    Charles T Nevin
    Charles T Nevin
    Terry Schneider
    Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
