I have a Proview RX 276 tv when initially turned on it works fine, if you turn it off then back on the green indicator light comes on but no picture any ideas, if I turn it off from the switch in the back, wait a minute turn it back on it works, any ideas
  • 8 Answers
SOURCE: proview rx 326 model 3200 tv sound but no picture
If the sound is working, I doubt the power supply is at fault. You can check with a simple voltmeter - red is positive, black negative - there should be 24VDC. There is an on-board regulator to drop the voltage for the CPU, etc, . THere is a green LED on the main board, so even if you don't have a Voltmeter, there is a visual indication that the power supply is somewhat functional.
I found a poor connection from the 24V power supply over to the inverter boards. I re-crimped the IDC connectors to the 24V supply and all was happy-town.
Posted on Jun 05, 2008
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
Posted on Jun 22, 2009
jhinsincity
  • 616 Answers
SOURCE: JVC AV-32F476 on timer green no picture no sound
Power supply failure, expect to pay $100-150. worth the investment JVC made some good tvs Julio milleniumtvsvc@gmail.com
Posted on Jul 22, 2009
John-INSG
  • 312 Answers
SOURCE: Insignia TV model NS-LCD19. TV shuts off
Unfortunately your TV will need to be serviced. You may take the unit back to the retailer of purchase to arrange for repairs.
Posted on Sep 25, 2009
tvservice306
  • 458 Answers
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Posted on Oct 02, 2009
KDS50A2000 Green light comes on briefly followed by red blinking light. 4 on then pause, etc. etc. Problem???
I tried this solution last night. had a similar issue. opened up the back panel and cleaned the fan. just for the fun of it, i tried to turn the tv on and presto. it works fine now and i probably saved a bundle. thanks!!!
Jan 25, 2010 | Sony KDS-50A2000 50" HDTV
No video but I do have audio Proview RX 276 TV 4 years old How do I reset system? Doug
It really doesn't have a reset for the picture. I would be looking at the inverter and power supply. If it is four years old most likely it is the inverter. The inverter is on the left side looking at it from the back. Have a repair shop check it out for you. Thanks
Oct 24, 2009 | Proview HV-177 17 in. HD-Ready LCD...
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
The green light comes on then turns to yellow.
if you look at the capacitors on the boards you will find several of them that are domed or blown, these are the most likely cause of the problem. you can find replacements for any capacitor online at electronics supply stores, like radio shack but don't try them they don't supply enough different types. you can also find examples of blown capacitors by doing a search for "blown capacitor image" on any web search. unsoldering these bad caps and replacing them with identical values like 220uf (microfarradys) and say 25 v(volts). these caps have a + side and a - side the caps are marked and so is the board. hope this helps.
Mar 20, 2009 | Proview PL926WBi 19" LCD Monitor
Proview 3200 RX-326 LCD TV loses BLUE
Digital brd has a heat related problem..If you did not get a extended warranty then it could be cheaper to just replace the TV...
Aug 28, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview HX303 30 in. HDTV-Ready LCD
Inverter board is tripping protective circuit. Check Caps!!! or Ballast's.
Jan 29, 2008 | Proview HX303 30 in. HD-Ready LCD...
Sony KP-51HW40 No Picture, only sound
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Nov 26, 2006 | Sony KP-53V75 53" Rear Projection...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
