Question about HP Office Equipment & Supplies
Printer not working suggestig out of paper and will not switch off
    Genius:
  • 2,785 Answers
Your printer needs servicing
Posted on May 16, 2008
Why does my Canon printer MX310 show paper jam when there is no paper jammed?
Hi
try switching printer off & on. If that doesn't work, check the paper path for stray bits of paper or another obstruction.
Sep 20, 2014 | Canon PIXMA MX310 All-In-One Printer
ERR 041
Must have Engine (fatal) and Jam Error logs display on the Control Panel or listed on ..... 041. paper jam. switch off the printer, remove its cartridge, look for paper jam or piece of paper jam in the rollers, clean it, place cartilage properly, switch ON the printer. it will work.
Jun 11, 2014 | OKI Electric Industry B4300 Led Printer
Hi my this model of printer is not pulling the paper..how to solve it?
Hi, Manually you can feed the paper right? top feed or front feed. LQ 300 has a sensor for paper feed, if it cannot feed paper automatically there could be something wrong with the paper feed sensor. Sensor of which is just a switch that once the paper pass, it will trigger the switch. If you can open up your printer, you can check the switch if still working. If you manage to locate the switch take out the switch and have check by ohmmeter tester to check the continuity. It sound technical but you can ask help.
Jun 21, 2011 | Epson LQ 300+ Matrix Printer
Printer will not work. Says paper tray not engaged.
Unplug the printer from the power and USB, Pull the paper tray in and out a few times, then plug the power and USB back in. If this does not work unplug it again, pull the tray out and look for a switch somewhere in the paper trays hole. this could be damaged or not triggering correctly. You may be able to rectify this by wedging the switch closed. Turning the printer upside down will help locate the switch.
Regards GM
Apr 08, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Showing Empty on paper, but paper in?
Hey,
Try push the paper to the end of the printer.
Love.
Feb 17, 2011 | HP DeskJet F380 All-In-One Printer
Canon printer pixma mp 150 - keep getting error e 2 when i try to print
Sir,
when your printer is not recognized paper or paper tray is blank.Then it show E2.Paper tray switch is not on or switch is not work.Please clean it soft brush.Reload the paper correctly and press black or color.
Jan 09, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have mp190, e-2 error code,not reading the paper,any ideas how to fix
Sir,
Dec 22, 2009 | Canon PIXMA MP150 All-In-One InkJet...
IAM USING HP DESK JET F2100 PRINTER MY PAPEROUT LED IS ALWAYS BLINKING AND NOT PRINTING
Possibly it either does not have enough paper in the tray - some printers require about half an inch of paper to work. Sometimes also the switch or feed on the paper try gets stuck, look inside to be sure the paper can feed properly onto the rollers, some printers have sort of a plastic piece that is spring loaded and moves, also look for a switch that may be stuck or if there is any tiny piece of paper that may be inside holding a switch open.
Oct 26, 2009 | Office Equipment & Supplies
Problem shows that it's paper jam but there's no paper inside the printer & its rollers.
On HP printers, there is small switches that sense where the paper is situated in the printer. One of these switches is most likely not completely back to it's upright position. This happens sometimes when the coating on the paper rubs off and builds up on the switches. Try opening the covers on your printer one by one, and reach inside for these switches. if you run your hand over these switches several times, you can usually get them to work right again.
Mar 19, 2009 | HP Office Equipment & Supplies
Printer paper will not feed into the printer
Your printer has a photo switch at paper feed section, this switch is triggered when there is paper and vise versa when there is none, check to see if there is/are some torn pieces of paper blocking or clogging the plastic lever from triggering the switch. A torchlight and a plastic pair of tweezers will help a lot.
Jan 05, 2009 | Epson Stylus Photo 895 InkJet Printer
16 people viewed this question
Seeker5211
Seeker5211
