Question about D-Link 3G Mobile DIR-451 Router
I reseted my router, and now it's misconfigured, apparently, re-reseting is not working, and the router it's not releasing an IP adress for my pc, so i can't view the GUI anymore, i don't know what happened, but it seems to be rebooting from time to time, anyway, i can't view it nor by a wired connection and neither by a wireless one. Is there any other kind of hard-reseting or so?
  • 128 Answers
You can always use the ip address and do the reset from the webpage when it comes up. It will restore to the default
Posted on Sep 15, 2010
My Cisco SPA502G does not ring for incoming calls
It is a problem with the router. if you assign it a public ip adress it will stay on line the other option is a router that will allow consistent nat translation
May 12, 2014 | Cisco SPA502G IP Phone
Renew ip adress
OK. You need to reset the modem to renew ip address from the current one.You can't reset the ip address using the router reset method.So reset or switch off the modem and then switch on it.Then new dynamic ip address will assign will be generate for your connection.Check ip address using the site Ip-Details.com before and after resetting modem...I hope you will get the answer by my reply.
Jun 15, 2013 | TP-LINK Computers & Internet
I WENT 2 RESET PASSWOOR OM MY AOPEN ROUTER WERE DO I GO 2 DO THIS
if your router's ip address is 192.168.1.1 then set you pc's ip adress to 192.168.1.2 mask 255.255.255.0 gateway 192.168.1.1. type http://192.168.1.1 in your internet explorer.choose reset factory default in you router's system menu.
Jan 18, 2011 | Computers & Internet
When i type my ip adress on my adress bar, it does repond.
Try to press the reset button with help of any paper clip for 30Secs. and Release it, Take out power cable - plug back in. Open IE page try 192.168.1.1
WARNING: If you are pressing the reset buttono of router - it will take all your settings to default.
Apr 02, 2010 | Linksys WRT160N Wireless Router
I changed the IP address on belkin f5d8236-4 v2 and can't get into homepage to reset the IP adress. Please help. Thanks in advance.
Restore it to facgtory default:
Turn off power
Depress the reset button on the bottom of the router.
Keep the reset button pressed and turn the power on.
Release the reset button after 10 seconds.
The default IP should be 192.168.1.1 or 192.168.0.1
Default passwords vary, but it is usually "admin."
Hope this helps,
BReady
Mar 27, 2010 | Belkin Computers & Internet
I recieve error that I can't get a Ip adress. WEP security password goes to the router but no Ip adress is making it back . I've tried loading a static IP adress, using another unsecured network. resetting...
Try using the HEX password instead of the ascii passphrase - also try to reset your AP temporarily in order to test the connection without ANY wireless security - if that doesn't connect, then the problem probably lies in the wireless router itself.
Oct 20, 2009 | Microsoft Xbox 360 Elite Console
DWL-G710 - Not able to logon with standard IP-adress 192.168.0.30
Must have same IP-adress on Router and Repeater 192.168.0.x. Then have cable from router to PC and from router to repeater. Then logon to repeater and the Dlink-repeater SW have a command where you can see available networks. See to that you choose the right one and that channel, name and password is the same as the router. The repeater will not be visible when you search for available networks because it has the same name as the router. I also had to restart the router and the repeater before it worked.
The repeater gives us excellent connection where we otherwise has no connection, so I can recommend it.
Aug 27, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Can't connect to web configuration
There is a reset known as a 30/30/30 reset. Hold reset with power on for 30secs, unplug power while still holding reset for 30 secs, plug power in while holding reset for 30 seconds more and release, wait 30 secs or more for reboot. This should put it back to factory defaults regardless of brand. Set your IP manually on the PC to be 192.168.0.2 Open your web browser and type in the IP address of the router (192.168.0.1 by default). Enter the username (admin) and password (blank by default), and then click Ok or Log In
Aug 26, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Http://192.168.1.1 is not working anymore? i cant set up the router
Try resetting the router, press the reset button at the back for 10 seconds, after that release the reset button and then unplug the power of the router, then wait for 10 seconds and then turn it back on.
After that try accessing the IP of the router 192.168.1.1 (if this did not work try 192.168.0.1,this varies on the model number of the router). Or follow the same steps you have done previously.
Aug 15, 2008 | Belkin (F5D5231-4) Router
Blocked mac adress
Hey,
Try holding the reset button for a little longer, say for 30 secs.
Keep an eye on the power light and the power light on the router should start flashing.
Than release the button.
Mar 27, 2008 | Belkin (F5D9230-4) Wireless Router...
D-Link 3G Mobile DIR-451 Router Logo
73 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
