Question about Maytag Neptune MDG5500AW Gas Dryer
Gas comes on then after 90 seconds shuts off but contuneus to turn indeffinatly
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 15, 2010
Induction fan comes on ignitor wont ignite
If the igniter turns orange and the gas fires for only a second or two then your heat sensor needs to be cleaned with sand cloth, if it does not turn orange then your igniter needs to be replaced.
Jan 17, 2015 | Amana Gas Furnace 90% Afue 45000 Btu...
Hi, I have a 1999 Mercury Mountaineer -- The problem is the Mountaineer is been sitting for 2 years I try to turn it on and it did not turned on-- I spray starting spray and it turn on for split second as...
if it hasnt been ran for 2 years, i would drain the gas. put some 90 octane gas into it with some fuel injector cleaner if it still dont start, check the fuel pressure by disconnecting the quick connector from the fuel rail should have 35-40 lbs of pressure if it is way low or none fuel pump is bad
Feb 08, 2011 | 1999 Mercury Mountaineer
I have a Johnson air ease 90 plus.I turn the thermostat up and exhaust blower comes on igniter comes on and i can hear the natural gas release for a second or two then igniter shuts off along with gas. Fan...
If the burners come on for a few seconds and shut off check the flame sensor near the burners and clean it with steel wool, usually this will fix the problem. The flame sensor is a metal rod that is immersed in the burner flame on the opposite side of the igniter. robhvac47_7.jpg
Jan 17, 2011 | Heating & Cooling
Hello, The problem is the ignitor comes on for a few seconds then goes out. The fan keeps running but no heat is coming out. Any suggestions? The model we have is Amana air command 90. Thanks.
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 28, 2010 | Heating & Cooling
Furnace blower won't turn on... Forced air gas furnace was working fine for three weeks. Now: Turn themostat up Gas comes on, pilot light obviously working Box heats up for about 90 seconds Humidifier...
If it indeed started that one time for a short period then cut out, the first place that I would start would be the capacitor located in the blower compartment. The capacitor gives the motor the need kick to start, and often times stays in the circuit to help the motor run more effeciently. This could very well be the problem.
If you have the option to run the fan from the thermostat, turn the fan to the "on" position and see if it starts. If it does, then it is not the capacitor.
Hope this helps
PS Your are correct about the "sensor" turning the furnace off, it is called a high limit switch and is there for safety. It is an automatic reset device, and will reconnect power once it has cool suffeciently.
Nov 10, 2010 | Dayton Gas Furnace Heater
Hello, I have an achiever 90 plus ruud, when I turn it on the flame ignites but after 3 seconds it goes out, it does this 3 times than turns off. Help?
Are you saying that main burner is coming on or pilot /hot surface ignitor or spark ignitor ? If your induced draft motor is coming on then a few seconds later your main burner is coming on for 3 seconds and then shutting off but blower motor is not coming on I would look at flame sensor to make sure it is telling the fan motor to come on. Normally they will try three or four times and then lock out. One easy way to check blower motor is to set your thermostat to fan on. Fan motor should come on and run till you shut it off.hope this help you.
Nov 05, 2010 | Heating & Cooling
My inducer comes on for 3seconds then shuts back off could there be something wrong with the pressure switch?
It begins its power-on cycle normally. First the updraft blower turns on for a bit, then the HSI glows bright orange, then the gas turns on and the flames ignite fully and the big blower turns on.
About 3 seconds after the gas ignites, it shuts off. That is the gas shuts off, the blower continues for about a minute then it shuts off. This cycle will repeat a few times, then usually after the second or third time everything stays on and works normally
Oct 30, 2010 | Kitchen Appliances - Others
York Diamond 80 furnace (propane conversion), about 1998 model. Solid Ignitor comes on, but no flame. Main fan works for about 90 seconds then cuts off. Fan only switch on thermostat does the same, fan...
Check for 24 volts across the two terminals on the gas valve when the ignitor glows. If yes, bad gas valve or blockage in the gas train. If no, bad ignitor or circuit board. Even if the ignitor glows, it still may be bad and not sending the proper signal to the board. If you jump the R and G terminals on the circuit board, does the fan still only run for 90 seconds? If so I would say replace the board.
Dec 28, 2009 | Heating & Cooling
CBN30T,DESA, pilot lights, but flames out when the burner comes on.. burner stays on a few seconds and shuts off due to cold thermo-couple. pilot flame seems to jump up and disconnect from the jet, as if...
ONLY ONE OR TWO THINGS AT FAULT.YOU HAVE A BAD THERMOCOUPLE.THIS IS PROBLEM 90% OF TIME AND CHEAPEST REPAIR.IF THIS DOES NOT SOLVE PROBLEM GAS VALVE IS BAD.HOW IT WORKS:THERMOCOUPLE WHEN HEATED WITH PILOT FLAME CREATES ASMAAL ELECRTRCAL SOURCE THAT HOLDS A MGNET OPEN AFTER HOLDING THE PILOT DOWN FOR ABOUT A MIN..THEN TURN GAS VALVE TO OPEN POSITION AND MAGNET WILL HOLD GAS VALVE OPEN.IF GAS VALVE DOES NOT STAY OPEN IT USUALLY INDICATES BAD GAS VALVE
Oct 13, 2009 | Desa International GWP30T Heater
Maytag Neptune MDG5500AW Gas Dryer Logo
43 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
