It beeps five times and no picture just five beeps
  • Paul Lyman
    Paul Lyman Sep 15, 2010
    What is the make and model of your computer?
  • Computers & ... Master
  • 5,660 Answers
The beeps you hear is a BIOS Beep Code.
The computer's way of telling you something is wrong, and an area to look into for the problem.
The BIOS Beep Code is sort of like Morse Code.
Instead of a series of dots, and dashes, it's a series of short beeps, and long beeps.
One example:
One short beep, two long beeps.
Then a period of silence, and the beep code starts all over.
There are different BIOS manufacturers that make the BIOS program.
(Basic Input/Output System)
Two of the main BIOS manufacturers are AMI, (American Megatrends Inc.), and Award/Phoenix.
(Award and Phoenix used to be two separate manufacturers, but have combined)
5 short beeps sound like one of AMI's BIOS Beep Codes.
http://www.pchell.com/hardware/beepcodes.shtml#ami
Part of the information given states to remove the ram memory module/s, ('Sticks'), and reinstall them.
I would also like to add to clean the gold plated contact pins, on the bottom of the ram memory modules.
Computer off, unplugged from power, and computer case open, observe Anti-Static Precautions BEFORE reaching inside your computer, and handling the ram memory module/s.
Use a pencil eraser to clean the gold plated contact pins.
Example of a DDR Sdram ram memory module, and it's gold plated contact pins,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can click on the photo to enlarge. You can enlarge twice)
The top of the ram memory module is towards the DRAM chips. (Black rectangular objects)
The bottom of the ram memory module is where the contact pins are located.
Suggest use the eraser on the top of each contact pin, stroking down towards the bottom of the contact pin.
If you are using an eraser on the end of a pencil, refrain from letting the metal band touch the contact pin.
Now use air to remove the eraser dust.
You can use a can of compressed air for computers, if one is readily available, or air pressure from your mouth will be sufficient.
Reinstall the ram memory module/s.
Close the computer case, plug the computer back into power.
WAIT 1 minute, turn the computer on.
Posted on Sep 15, 2010
2003 f 250 super duty truck five beeps five times
5 beeps 5 times - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Jan 2, 2009 - 5 beeps 5 times Super Duty & Heavy Duty. ... 2003 F250 4x4 CC V10 4" Procomp, all white beauty "list of previous owned Fords much to long to ... Beeping under my dash
Jun 17, 2012
Getting these strange beeps from Dashboard
Nov 13, 2010
beeping noise
Dec 22, 2009
5 beep tones 2000 f250
Oct 14, 2015 | 2003 Ford F-250 Super Duty
Xps 8700 five beeps and five beeps starts windows goes to power save mode
Sundeep B posted this July 2013 on the DELL.COM>Community>Support Forums>Desktop>Desktop General Hardware Forum
DEL5 beep error code indicates an issue with RTC power and indicates an issue with CMOS battery. You may try reseating CMOS battery. You may refer to Owner's Manual Here. The location of CMOS battery is as shown below :
The video cards mentioned by you should function properly, however, Dell has tested XPS 8700 only with following video cards :
  • nVidia GeForce GTX 660 GTX 645 GTX 650Ti GTX 660
  • AMD Radeon HD 7570 HD8870
Dec 10, 2014 | Dell XPS 8700 Desktop - Windows 7
Why the air bags make a warning sound beep
Need to get it to a reputable repair shop. Have them check for fault code in restraint system. You're getting a code 15 that's telling you there's a concern with the drivers side air bag, module, wiring, or component failure. Possibly a clockspring but that's only a guess. If you were to get in an accident the bags would not deploy, when module sees a fault it shuts down the system to prevent false air bag depl
Jun 29, 2014 | 2000 Ford Expedition
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
Glove box beeps
does the air bag light prove out when the key is turned on?
Nov 25, 2008 | 1995 Ford Crown Victoria
Umpossible to take pictures
might seem silly, but have you checked the batterries?? The beeps usually signal a loss of power, if not check shutter is not jammed with dust particles, use compressed air to shift it.
Sep 11, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera beeps five times, doesn't work
the beeps mean the lens can't be opened or closed. maybe something stuck or it's just failed?
Aug 30, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
