Question about Sony PlayStation Portable (PSP) Console
I have 6.31 and i want to change to a 5.5 or 6.0 how can it be done?
    Scholar:
  • 120 Answers
First of all you need a pandora battery, This will put your PSP in to service mode and will allow you to install custom firmware or recover a bricked (Broken)
Next you will need a magic memory stick, A magic memory stick holds the files needed for your PSP to boot in to a firmware installer, You then follow the prompts on screen. Easy !
http://www.pspmod.com/shop/
get files and more info here
http://www.pspmod.com/forums
Posted on Sep 15, 2010
Error code 31 CD ROM driver not available how to install this driver
  1. Restart your computer if you haven't done so already.
    There is always the remote possibility that the Code 31 error you're seeing was caused by some temporary issue with Device Manager. If so, a simple reboot might fix the Code 31.
  2. Did you install a device or make a change in Device Manager just before the Code 31 error appeared? If so, it's very possible that the change you made caused the Code 31 error.
    Undo the change if you can, restart your PC, and then check again for the Code 31 error.
    Depending on the changes you made, some solutions might include:
  3. Delete the UpperFilters and LowerFilters registry values. A common cause of Code 31 errors is the corruption of two registry values in the DVD/CD-ROM Drive Class registry key.
    Note: Deleting similar values in the Windows Registry could also be the solution to a Code 31 error that appears on a device other than a DVD or CD drive. The UpperFilters/LowerFilters tutorial linked above will show you exactly what you need to do.
  4. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 31 error is a likely fix for this problem.
  5. Replace the hardware. As a last resort, you might need to replace the hardware that has the Code 31 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you're convinced that hardware isn't the cause of this particular Code 31 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those before you try replacing the hardware, but you may have to give them a shot if you're out of other options.
Applies To
The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Aug 16, 2016 | Computers & Internet
1996 jeep cherokeecranks no spark on coil or distributer
Test procedure:
1. Test powers and grounds at the Powertrain Control Module (PCM) on the C1 connector. Pins 2 and 22 are power, then check pins 31 and 32 for ground.
2. Next, test the 5 volt power supplies at pin 17 of the C1 connector and pin 31 of the C2 or middle connector for shorts to ground. Sensors on the circuit are the Camshaft Position (CMP) sensor, Crankshaft Position (CKP) sensor, Throttle Position Sensor (TPS), Manifold Absolute Pressure (MAP) sensor and Vehicle Speed Sensor (VSS).
3. Unplug the sensors on the 5 volt power supply, one at a time, while monitoring the 5 volt supply.
4. When the shorted sensor is unplugged, the PCM will wake up and scan tool communication will return.
5. The wiring harness could also be shorted to ground on one of the 5 volt power supply wires. Cut the wires at the PCM on pins C1-17 and just unplug the center connector. Then check for the 5 volts on the PCM of the connector or checking for any continuity to ground with the sensors unplugged at the PCM connector on C1-17 and C2-31 to check the wiring harness
Nov 16, 2013 | Cars & Trucks
5I+5(I-31)=55 how do i solve this
Start by using the distributive property to expand the term 5(I-31)=5*I-5*31=5*I-155.
Rewrite the equation as 5*I+5*I-155=55
Combine the terms with I, this yields 10*I-155=55
Add 155 to both sides of the equation 10*I-155+155=55+155
you now get 10*I=210
Divide both sides of the equation by 10
(10*I)/10=210/10
Cancel the 10's on the left and divide 210 by 10 to get 21
Thus I=21
Basically you use the priority order of operations BEDMAS backwards
Feb 13, 2013 | SoftMath Algebrator - Algebra Homework...
I have a Vodavi Starplus STS DHS 30 button setup. Trying to change Time/Date on the phone but every resource I see starts with the Feature [FEAT] button. My phones, admittedly a little older (5 years),...
Programming
1.
time is done at the attendant console (more than likely 100).
Dial [692] on the dial pad. A confirmation tone will sound.
2. Enter date and time as follows: YYMMDDHHMM 3. YY = Year (00-99) 4. MM = Month (01-12) 5. DD = Day (01-31) 6. HH = Hour (00-23) 7. MM = Minute (00-59) 8. When the correct number of digits are entered, a confirmation tone will sound. 9. Press the ON/OFF button to OFF to update the display.
Oct 13, 2010 | Vodavi Starplus DHS SP7312-08 - - Phone
Hi, I have a emachines by acer laptop and it does show me that windows 7 have an error code 31. I have tried already to fix it by doing the system restore, I dowloaded the drivers that have being deleted...
Please let me know if you've fixed a Code 31 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Applies To The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Jun 18, 2010 | Computers & Internet
Fixya expert login denied
dear sir
i think you have solved 31 solutions. but how much rating ou have done. your rating must be 5 approximately
regards
murali
Dec 10, 2008 | FixYa Service
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
