Question about Toro Garden
How do you change transmission belt & drive belt on 2006 Toro LX420 lawn tractor?
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
  • 61 Answers
SOURCE: Roper 16 hp Lawn Tractor: belt replacement
you need to remove the mower deck there you will see the pullys.
Posted on Sep 06, 2009
bbreton
  • 437 Answers
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Posted on Oct 14, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
  • 3074 Answers
SOURCE: i have a 2008 cub
this is a detailed manual and will explain everything, Good Luck Tim:
http://cubcadet.custhelp.com/app/answers/detail/a_id/1722/~/cub-cadet-technical-service-manuals
Posted on Jun 01, 2011
What is wheel drive belt size for toro lx 426 lawn tractor
Motion drive consists of two belts,
Engine to variable speed pulley 5/8 x 90-1/2
Variable speed to transmission 5/8 x 42
May 30, 2015 | Toro Garden
I drained my oil in my toro and it had gas in it lx420
the float in the carb is stuck open allowing the cylinder to flood with fuel. Clean or replace the carb and try it again
Feb 03, 2013 | Toro LX Lawn Tractor Rear Tire Chains (20"...
How do I change the drive belt on a Toro LX466? Also, what would cause this lawn tractor to go thru one drive belt a year since 2008?
well I have a Lx 500 and the problem is that the bearings on the pulley shafts are wore out, makin the pulleys hard to turn or dragging heating up your belt. It heats up from the friction of the pulleys not free spinning like they should. next time you have the belt off check out the pulleys and see if they spin freely that will be the tale tell sign.
May 04, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
How to change the drive belt on a Toro 20016 SP Mower
The Toro 20016 mower is a front wheel drive mower and fairly simple to change the belt on. Start by disconnecting the spark plug to prevent start ups while working on the machine.
Remove the blade and adapter. The adapter includes the pulley for the belt.
two screws under the mower, with 3/8 heads hold the black cover over the belt. remove the cover and now you will see the transmission
The transmission, depending on the year of your machine will have a guard holding the belt on. Bend or remove the guard to remove the belt. Install you belt in reverse order.
You can get parts and special tools like the blade stop at a store like www.arcolawn.com
Feb 23, 2011 | Toro Lawnmower Lawn Mower Sp Drive Belt...
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
301 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
