Question about Acer Aspire 3004WLCi Notebook
Laptop does not power on !
Got a problem that the laptop does not power up and no LEDs light up when power connected to laptop. Stripped the thing down and it worked ok for 1 week, but now gone completely dead .. and I'm thinking that this could be a thermal problem and that either the fan is now dead or processor is overheated. I've got a question on the fan and a question on the processor :-
(1) Would a faulty fan cause the PC not to power up ? .. do the fans fail often ? ... and what are the chances of getting a replacement fan ?
(2) Would a swapout for another sempron processor help in any way ?
Many thanks for any help
Ian
    Genius:
  • 1,027 Answers
The fans for most laptops are 2 stage. And again most laptops have a thermal parameter that they operate in. When processors overheat they will shut down.
If the processor is gone, or going, you should still have a light on showing the either condition of battery or elect. supplied.
I was working on a Toshiba that had "ISSUES". Thermal problem caused by fan, fan would go to high speed for 2 sec. when first turned on then stay on low. The unit would not boot, black screen etc, until I removed and reseated the processor. Then everything would be OK for a week then start all over again.
I ended up replacing the power supply brick, processor, heatsink and fan.
Posted on May 16, 2008
    Genius:
  • 2,785 Answers
First of all change ac cord and batter then try with the fan
Aod255e wont boot
what is the meaning of won't boot. is your laptop powering on or not. did you see any leds lighting up.
if leds are lighting up then it might be a incorrect ram seating or hard disk might be not connected properly.
if no leds are lighting up. then check your system with the adapter connected.
if it is turning on by adapter connected. then your battery is dead. try to replace your battery.
if you have done all of this. just reset the bios.
WARNING: if you don't have any knowledge of opening a laptop, then don't do the following steps. it is your responsibility for any unnecessary damage.
just open the back cover and reset the bios settings by removing the CMOS Battery inside the laptop.
if you have done this also. take your laptop to ACER service center
Feb 17, 2012 | Acer Aspire One Aod255e-13648 10.1"...
When i press the power button on the nw8440 the charging light just flick several times but it does not start
Chances are, you have a bad motherboard. You can try one thing. In my experience, it works about 10% of the time.
Unplug the power cable from the laptop. Remove the battery. Press and hold the Power button on the laptop for 30 seconds (This will drain the power from all components). Put the battery back in the laptop. Connect the power cable. Try to turn it on. Again, in my experience, it works seldomly (I promise I've seen it work several times, though).
If that doesn't correct your issue, you may have a DC jack which has solder joints broken. If your laptop charges "sometimes" but not others, this is probably you. The DC Jack is the component inside of your laptop which the power cable plugs into. Over time, whether you do as much as trip over the cable down to just laying the laptop on your bed (it will sink down and put pressure on the DC jack/power cable), the DC jack may have wiggles itself free of the solder joints holding it to the motherboard. This is not a cheap repair.You can test this by giving SLIGHT upward pressure to the power cable at about an inch away from the edge of the computer. Keep an eye on the front LEDs. If no other LEDs light up, then you probably have a bad power cable. If, when gently pressing up on the power cable, you get an LED to turn ON, then you have a bad DC jack.
In either case, the only fix is to take the PC to a computer repair shop.
I hope this helps and thank you for using Fixya.com.
Sep 22, 2011 | HP Compaq nw8440 Notebook
MY LINKSYS WRT150N ROUTER WAS CONNECTED TO THE MODEM VIA CABLE.IT WAS WORKING NICELY FOR WIRELESSLY CONNECTING TO LAPTOP AND IPOD AND ANOTHER LAPTOP/DESKTOP WITH A ASUS USB ADAPTER.THE...
Try turning off the power wait for 30 secs and reconnect the power and check if the LEDs light up again.
IF NOT THEN -
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 06, 2011 | Linksys Wireless-N WRT150N Router
Tried to charge laptop light comes on but laptop will not switch on
Try to remove the battery from the laptop and turn it on with the power cable connected.
If the power leds are turning on but nothing comes up on your computer, not even the BIOS, your motherboard may be damaged.
May 17, 2011 | Computers & Internet
When power os switched inonly leds glow but nothing comes on screen.
hi there,
try to unplug every thing connected to the laptop, even the power supply. Now disconnect the battery. Now press and hold the power button for 30 seconds.
Reconnect the battery and power to the unit. now try to power on the machine.
You should be good to go.
In case that this does not help, I suggest you visit the service station
Jun 24, 2010 | Computers & Internet
Laptop is not switching on..no leds turning on ..dead!
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 23, 2009 | Acer TravelMate 2300 Notebook
DELL Precision M65- cannot turn on. Even take off batt then turn ON, or using adaptor without battery still cannot turn ON. The LED light is ON but no visual/screen. Please help. Many thanks...
Verify the AC power adapter displays a solid green or blue light. Older Latitude™ C Series laptop computer AC adapters may not have a light.
Run the diagnostics on the system as follows , connect both the battery and the Ac adapter before running the diagnostics
  1. Ensure the system is powered off.
  2. Remove all external peripherals.
  3. Press and hold the <Fn> key on the keyboard.
  4. Continue to hold the <Fn> key while pressing the power button.
  5. Release both buttons.
  6. Note which lock LEDs are lit (lock LEDS are next to the power button)
And proceed with the troubleshooting steps listed below
http://tinyurl.com/m3k22x
Thanks for using Fixya
Proton
Jul 13, 2009 | HP Pavilion dv6000z Notebook
Laptop help
The "loud beeps" are the BIOS telling you what's wrong. Check the manufacturer and/or manual to find the error code(s).
Jan 16, 2008 | Computers & Internet
Toshiba Satellite 1135-S125 front LED indicators gone weird
Hi The strange operation of those LED's is most probably an error mode indicator. If a laptop fails to power on corectly it will use those LED's, lighting in a specific pattern to signal the error. That's an example. In your case something was damaged in some way because the error code indicator is still acting like there is an error. You may try to reset the BIOS to factory defaults (small chances that this will work) and leave the laptop unpowered for about 1 day. If the problem is still there you will need to have it fixed in a service center. By comparing the LED lighting pattern with information from the Toshiba service catalogs they will be able to tell you what kind of error had happen for wich the LED's to light in this manner. Sorry for my bad english, I live in a non-english speaking country. Good luck and don't forget to rate any answer received from this site.
Mar 05, 2007 | Toshiba Satellite 1135-S125 Notebook
Acer Aspire 3004WLCi Notebook Logo
235 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
