Question about Toshiba Satellite A215-S4747 Notebook
My toshiba just keeps acting like it is going to reboot then it shuts off. Whe ou turn it on it keps doing the same thing, we tried a new hard drive but that didn't work either
    Sergeant:
  • 235 Answers
Press the f8 key when it attempts to restart. It should go to a menu with several options. Choose the option that says, "Diasable automatic restart on system failure." and it should go to a blue screen with a message about your error. Write down the error and 'google it' on a working computer and it should give you a good idea of what is causing the problem. Good luck.
Posted on Sep 15, 2010
Hi my daughter didn't shut down my toshiba satellite A300 properly. She just press the turn-off button. the problem is I can't reboot it anymore. It keeps on restarting even if i choose the safe mode. ...
Sorry about this...
Do the full H/W diagnostic test on your Laptop & see which thing causing problem..I am sure you will Toshiba Diagnostic CD...
Boot system from that CD & try it..let me know if you need any more assistance...
rate this , if you like.....
Thanks
Sandeep
Mar 11, 2011 | Toshiba Satellite A300-0CF035 Notebook
My Toshiba inspiron 6400 will freeze at at first booting to windows and if I shut it down and restart it keeps tripping and will not even boot. need help.
I'm not 100% sure whats going on, but i had a similar problem with my sisters computer the other day. The head on her hard drive crashed, which means that the part that reads the disk literally crashed into the disk surface, digging a groove and rendering it unreadable. It waould continuously reboot after that. The fix? buy a new hard drive. consult a professional and have them look first before you do that; ii don't want you to spend all that money on a new drive and have it still not work.
Feb 11, 2011 | Toshiba Satellite A135-S2276 Notebook
Device came with no instructions. How do I verify that my data has been downloaded onto the device? How do I pull the data out of the device? I tried to reboot some pictures from the device to my...
check my computer with drive disconnected note all drives,shut down connect drive reboot go to my computer any new drive found should be external h/drive good luck!
Jan 08, 2011 | Toshiba 500GB USB 20 Portable Violet Hard...
Greetings: I have a 500GB Toshiba external hard drive which has begun to act a little peculiar; it still has all its data and works if plugged in during the laptop boot-up. One folder does not respond...
Patition Magic That The One You Need ....Chek On LimeWire...Or Any FreeWare Domaine.. On the Net ..Try Google..
(exemple Type download Patition Magic for XP
Oct 06, 2010 | Toshiba 120GB USB 2.0 Portable External...
Satellite M45-S351 locks up won't shut down. First thing, may lap top would not shut down so we had to use the power button, then after some time 2-3 the unit decided not to boot up. we copyed the hard...
I think it is a prob with the mother board.........no need t change RAM or hard drive........they dont cause this type of prob. Ur mother board is not accepting the shutdown command.
Try the following command in command prompt:
shutdown /s /f
May 23, 2010 | Toshiba Satellite M45-S351 Notebook
Toshiba laptop not loading up what can i do
if you keep on getting this message but your laptop is booting, have your hard drive check if still working or not or the operating system is corrupt or deleted
Nov 21, 2009 | Toshiba Satellite A100-S8111TD Notebook
Dell XPS M1330 laptop doesn't boot just shows colored lines...
Multiple problem issue going on here, with the screen having those lines popping up the way it is, the screen is definitely going to need to be replaced.
Hard drive is a more touchy issue. Not sure if you put a new one or a refurhbished one in the system. If it was a used one or refurbished one, I would suggest putting a new one in the laptop to be sure the hard drive is good and then reinstall the OS and put the drivers back on. That would be my suggestion.
The other thing to try would be to make sure your memory is good. If you have more then one stick, try each stick one at a time and turn on the laptop after inserting just one memory stick into the drive, and then repeat the process with the other and see if the laptop does the same thing each time, if it does then you know the memory is good, if you can get it to boot up into windows with one memory stick but not the other then you know one of the memory sticks is bad.
In fact try the memory swap first and then if that doesn't get you anywhere then try a new hard drive in the laptop.
If that doesn't get you anywhere then you know for sure the motherboard is bad.
Sep 04, 2009 | Dell XPS M1330 Notebook
My gateway laptop 7330gz hard drive is locked and asking for passed word and it can't reboot.I try to reinstall windows using a different hard drive and when it reach format disk it keep shutting off.
Without that HD password, you are out of luck. Only thing you can do is install a new hard drive, and reload everything. You cannot even retreive any data you have on a passworded hard drive without the password.
May 04, 2009 | Gateway 7330GZ Notebook
Toshiba Satellite A215-S4747 Notebook Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
