Question about True Refrigerators
My cooler cools, but after a couple of days it quits, and starts to get warm. I shut it off for an hour or two, then turn it on and it works again. Is it my thermostat.
  • harrison343 Sep 15, 2010
    Thank you, My unit is actually just a cooler. It is a True two door cooler no freezer on the unit.
    Does this make a difference?
    Thank you it was helpful!
  • 944 Answers
Due to various reasons this problem could occur:
1)First you have to resolve for the cause of the issue.
First Check the back wall or floor of the freezer section for frost.The Freezer(evaporator) fan is running?.This fan problem is very hard to detect.
The DC motor for the fan wears out the RPM's are effected.It gives the illusion that it is running fine,but it don't have enough force to supply air circulation for both the freezer
and the refrigerator See weather the condenser coil for
blockage from dust and the condenser fan is running.
2)Check the temperature setting.
Set it to max and min and check for any changes you can see in the system.
3)The the freezer vents cold air to the refrigerator.Occasionally the vent can become clogged with ice, food or other debris. Locate the vent and clear it. To remove ice, use a hair dryer set to "low". Using the high setting may cause damage to the components or interior of the refrigerator.
4)Defrost timer:Usually the defrost timer could solve this issue.It may be located below or back of the refrigerator.Some times it may be located in the side to for side refrigerator.Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 30-35 minutes.Then there is no problem with Defrost timer.
5)Heater and defrost thermostat is located behind the back wall of the freezer section.
This only controls the Heat.After the Defrost timer stops it makes the system warm.
Defrost thermostat could be defective.
Heater.
Thermostat.
In side by side refrigerator the defrost timer is embedded with temperature control board
so you have to do continuity testing on the board to find out the exact cause.
Use ohm-meter to test the parts.To test defrost heater and defrost thermostat they will have two wire endings keep the ohm-meter two ending on each probe.
Since you do it for 2 hours the the Refrigerator will not fully defrost.It will take
atleast 8 hours more to melt he forst ice at the back panel of the Refrigerator.
For time being Solution:Switch off your Refrigerator for 10 hours or more and melt the "snow" build-up in the freezer section.Use hair dryer to melt it quickly.Now switch on the system and see the cooling effect.It will be increased.The snow" build-up in the freezer section will not allow the cool air to flow into the Refrigerator.There will be valve in the backside through which cool air flows.
Posted on Sep 15, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 15, 2010
    You have raise the question in Refrigerators cooler section.So i gave you general ideas.
    If it is only cooler.Then basically it is the problem with the thermostat only.It controls the coolness in the cooler.When it is on, the circuit will heat the cooler.
    In normal refrigerator the cool air is flown from drain hole to the the Refrigerator section.In your case it directly flows from the compressor and the evaporator fan flow the air.
    Check the evaporator is running?Defrost system is same as all refrigerators.Defrost system controls the coolness.So check it.
GE GSL25JFTABS freezer quits then frig quits cooling
Probably your auto defrost element(s) is (are) burned out.
Aug 13, 2014 | Refrigerators
Ice build-up on GE ZDW24A wine cooler cooling coil
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
Nov 04, 2009 | GE ZDW24A Wine Cooler
Door left open, now fridge won't work right.
Shut down the fridge for 10 - 15 Minutes and leave the fridge door open, and push the Defroce button
ANd start the fridge again and after some time check the temp.+ after some time.
Thanking you,
Your Tech Support
Manish Shirsikar,
Fixya.com
May 18, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Problem when I turn on my Toshiba Satellite a 200 1cr...!
Sounds like it might be a thermal problem: it works when warm but not at room temperature. Suggestion: While off, put in in a warm place (not too hot, just on the order of what it feels like after it has been running for a while), then turn it on. See if it starts working any sooner when it is already warm. Or, conversely, see how long it takes to stop working after it has been on for a while (turn it on and back off periodically to check), then get it warm and stick in the refrigerator (to cool off faster) and check periodically to see if it stops working sooner. There are some other things, like electrolytic capactors in the power supply that might "deform" excessively quickly when they are not energized, too.
May 13, 2009 | Toshiba Satellite A200-S18X01G Notebook
Refrigerators Logo
1,310 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
