Question about PfaFF Sewing Machines
WHen i switched on the Pfaff 2170, the message "sensor (6) not found". What does it mean? I cannot sew any stitch patterns at all except the Straight stitch. The motor also runs very slowly. Where is this sensor 6?
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
  • 136 Answers
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Posted on Jul 12, 2009
sew helpful
SOURCE: I can't get my Pfaff 230a to straight stitch!
The stitch selector switch is most likely the culprit. Have you tried operating the machine upside down?
Posted on Jan 17, 2010
SOURCE: PFAFF 362 Sewing Machine: The shift
I just fixed this on my pfaff 230-the problem is the needle position dial-the middle dial with the chrome lever on the right-has froze up .
remove the dial-it doesn't come off by the screwhead in the middle of the dial ,the screw you need to loosen is the one under the wider end of the part of the dial you hold-you will need a glasses screwdriver.
once it is off ,heat the exposed shaft with a heat gun while turning the shaft back and forth with pauses for dripping 3 in 1 oil on the shaft so the heat melts the hardened grease and draws the 3 in1 in to flush out the old grease and lube the shaft.
eventually you will be able to turn the shaft easily-then when it cools off replace the plastic dial.make sure your upper dial is on "0" there is a cam on it that will push down the other end of the chrome lever.
This will work-there is no plastic in the shaft and arm assembly to melt and you don't have to dissasemble from the top-that sucks.
Posted on Feb 04, 2010
HOW TO DELETE SEQUENCES FROM MY PFAFF AMBITION 2.0 SEWING MACHINE?
The instructions on pg 40 of the manual says to hold the Delete button in for a longer period.
quilt ambition 2 0
http://sewing.patternreview.com/SewingDiscussions/topic/89785
Also found the following comment to a review:
Jo-Ann16 May 2013 at 07:30
"Hello, I have the ambition 1.5, absolutely love it. To switch the font to normal stitching you have to delete or save the sequence. To delete it just tap the little garbage photo and to save tap the heart. With that done you then go back to your stitching tab select a stitch and tap the little garbage bin to erase sequencing and go back to normal stitching."
Mar 06, 2016 | PfaFF Sewing Machines
I have a 3D/ Pfaff 2170 Creative & I'm using Windows XP. No device found error. I can not transfer the embroidery design to 2170 Pfaff. Help!
Sounds like you don't have the device driver on you computer for the sewing machine. Question: Did it ever work? If it used to work but doesn't now, try using a different cable from the computer to the sewing machine. You can also try rebooting the computer (with the sewing machine connected and powered up) to see if it will locate the machine.
Dec 19, 2014 | PfaFF Sewing Machines
How do you change straight stitch length?
There is a length switch that you must turn carefully. Just monitor the distance of movement on an old rag and make some marks on the switch or dial as you go.
Apr 27, 2014 | PfaFF Quilt & Craft Pro 7530
Straight stitch has peaks
Check your stitch pattern because you most likely have machine set to perform a blind stitch. chane your pattern setting to desired stitch and make sure you use appropriate foot attachment for the results you want. jimmy
Apr 03, 2012 | Brother XR-65t Mechanical Sewing Machine
My 7510 says "adjusting pattern" 248 when I turn
I had this problem a few weeks ago. A new baseplate fixed it. You will need to take it to a Pfaff repair shop
Mar 27, 2011 | PfaFF Creative 7570
Pfaff machine 2170 stating 'error sensor 6' ??what does this mean??
The manual should have a troubleshooting guide for reference and guidance.
Apr 10, 2010 | Sewing Machines
Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
Feb 22, 2010 | PfaFF Sewing Machines
Jan 17, 2010 | PfaFF Sewing Machines
Pfaff 2170 Query
my pfaff 2170 machines shows "Cannot make Directory" pls help me in this
Apr 26, 2008 | Sewing Machines
Sewing Machines Logo
113 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
