Question about Watches
Need to have directions installing g shock battery
  • 831 Answers
Thank you for contacting FixYa.
I would recommend having a professional doing it. But if you insist, I found a tuturial that gives great instructions and pictures. PLEASE know, I have done hundreds of batteries, and I grimmace to do these so be forewarned.
http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html
Best regards. Jewel
Posted on Sep 15, 2010
My g shock is stuck on getting the moon graph
Check your rechargeable battery level.When MED or LOW (M or L) some functions are disabled in order to save energy to keep time (at least) running.If L,recharge immediatelly by exposing the watch to direct sunlight (not behind window glass) for 5-6 hours.Check the battery level in the mean time.Recharge more,if needed.
Jan 23, 2013 | Casio GW7900B-1 Mens G-Shock Solar Atomic...
I have G-shock 3011 and it stopped working after a session of sea walk
if you dry the watch out completely and the battery is good it might work again. when the battery is removed there is often a couple of pins you need to short out before the watch will work
Apr 06, 2012 | Casio Watches
How do i replacs the batterie in a g-shock illuminator
<P>Thanks for contacting FixYa.</P><P>Found a great tutorial for you.</P><P>Ive been changing batteries for 25 years and I wouldnt touch this one, so best of luck to you!!</P><P><A href="http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html">http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html</A></P><P>If you do this one, then you should get in the biz for sure!!</P><P>Jewel</P>
Aug 26, 2010 | Casio GShock Illuminator watch
Casio g-shock protection model blank face after new battery installed by a jeweler
What kind of battery did they put in it?? G shocks are powered by a rechargeable solar battery!!! Should not have been replaced unless it was the same type of battery. I would be going back to jeweler and asking them to send your watch to Casio and they pay for the new solar battery. Let me know what happens.
Aug 19, 2010 | Casio G-Shock 800D 7V watch
I have a gw300 and the battery is dead and i am looking for a new battery.
buying battery is not a problem its resealing so your watch is water resistant.you need a watch repairer who has water resistant chamber that gives you a print out of the depth they simulated in the test,these are more acurate than the manual chambers some repairers use so always ask. the battery number on the g shock watches is on the battery so take the screws out of case back and be carefull there are a number of springs on movement that control alarms et its always a 3 volt battery 2025or2035 or 2016. but remember if you try your self you have AC the movement wich is like jump starting a car.get it done by a pro is my advice.if not blog again and i will go through the sequence for installing cell .
Mar 26, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
G Shock G-600 Reset
Dual batteries should be installed [+ to -][+ to -]. There may be a hard-to-read diagram that shows installation. You may have to take the watch to a jeweler to get things straightened out.
Apr 26, 2017 | Casio G-Shock G600-1AV Wrist Watch
I have a casio G-Shock watch,And recently had a fresh battery installed, How do I reset to the Atomic Clock? Not getting the Signal.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
Mar 04, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
My Casio MTG900 seems to be dead. How much is a battery and where can it be serviced near Los Angeles?
Thanks all! My G-Shock was only in need of charging in direct sunlight as opposed to indoor lighting.
Nov 01, 2009 | Casio G-Shock MTG900DA-8V Wrist Watch
Battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
48 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
