Question about Maytag Ovens
Maytag model # crg7500aaw old model oven does not light igniter works
3 Suggested Answers
SOURCE: Maytag oven will not light
Having same problem.  Broils works.  Oven set to 350 then registers 100.  No gas no heat.  does anyone know the fix?
Posted on May 15, 2008
reg501
  • 413 Answers
SOURCE: Oven stop working
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
Posted on May 31, 2008
I have a maytag model # mgr5775qdw and the oven will not ignite. I know it is not the gas line as the burners all light, and the broiler lights as well. It is only the oven that does not heat. . .what...
This could be two possible problems. The igniter maybe bad, but doubt it. The igniter works both the oven and broiler, I believe on this model. The first thing I suspect is the switch in your wiring harness. The harness has a switch attached to it for each manifold. The switch for your oven maybe out.
Go to this site for diagram of parts: https://www.maytag.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20W10282172.pdf
Jun 18, 2011 | Maytag Ovens
My maytag oven CRG 300 gas oven will nit light when wanting to use the oven. the top works well. i have pilotless ignition. wht will it not light. I hear the ignition and hear gas.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jan 29, 2011 | Ovens
The broiler does not turn on in my Maytag free standing oven. The ignition light glows but no flame comes on. You can not smell any gas. Any suggestions?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 16, 2011 | Maytag Ovens
Maytag gas range model CRG9700C Turn the oven on and the igniter glows but the oven doesn't light. The top broiler works fine. What parts do I need and is it a very complicated repair?
Jan 11, 2011 | Ovens
When I turn my oven on it takes a long time to light. then when it does it lights with a bang. It never gets real hot either. my oven lights but the flame is very low. The broiler never did work. What...
The problem is the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jun 04, 2010 | Maytag CWG3100A Gas Single Oven
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Maytag gas oven mgr5770abb Does not light when I try to use oven. Broiler works fine. When I try to turn on the oven, the broiler igniter does not glow. If the bottom igniter was bad, wouldn't the top one...
first I would check to see if you have power (120v) at the bake igniter..when you set in to bake...use a multmeter..(when you turn on the oven to bake only the bottom igniter will come )
good luck be safe
let me know if I can help
Aug 15, 2008 | Maytag CWG3100A Gas Single Oven
Maytag gas Oven GA347BXUWX
hi there,
if it's just the stove, it's not the control board because the rest of your stove work. if it's just the oven, it most likely the thermostat, blower or the heat probe. go to www.reliableparts.com to get parts for it.
Aug 07, 2008 | Maytag CWG3100A Gas Single Oven
Oven stop working
May 21, 2008 | Maytag Ovens
Ovens Logo
44 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
