Where do I get parts for an embassy shreader model TQ121Ee
Setting date on embassy quartz watch
Google (embassy)(model)(manual) without parens for instructions.
Jan 28, 2017 | Watches
Have a Staples Model SPL-727MM paper shreader that won't work. Probably jammed, but unable to open it. Found some screw holes in where the tray pulls out, but regilar screwdriver won't fit, too long. Does...
Some home office shredders have the shredding mechanism "permanently" attached with only the bin (tray?) removable. The entire machine has to be inverted to gain access for cleaning. Periodic cleaning is necessary maintenance as shredders of this type are not self-cleaning.
May 17, 2014 | Office Equipment & Supplies
I want to know the exact address of philippines embassy in manila
*******....Manila is capital of Philippines, you expect a Philippines embassy in Manila....???
Can you find a US embassy in Wasihington DC ?
Can you find a Australian Highcommission in Canbera ?
Can you locate a Japanese Embassy in Tokyo ?
Can you locate a Singapore embassy in Singapore ?
I can go on......
******* your question is a **** ?
Nov 29, 2010 | Computers & Internet
Need manual for sears craftsman 113 79890 vacuum shreader bagger
Go to this site and input your model number and they should have it.
http://www.searspartsdirect.com/partsdirect/index.action
Once the parts page comes up, you will see a tab for the owners manual.
Nov 23, 2010 | Sears Vacuum Shredder Bagger Replacement...
Have a Troy Bilt chipper/shreader model 47285. I
Taked the broken belt to the auto parts store for a replacement.
Jun 06, 2010 | Troy-Bilt ChipperShredder
PS60C-2 Shredder: Fellowes P50CM paper shreader motor runs but cutte...
One of the drive gears has stripped its teeth, usually caused by overloading the machine. These are personal shredders and parts are not available in my experience.Sorry.
May 03, 2010 | Fellowes Office Equipment & Supplies
917270181 need readable print of parts related to this shreader. The parts breakdown you have on your site is unreadable and does not list part names with corresponding numbers.
You can go to: www.searspartsdirect.com
Put in the model number and it will open up to an interactive picture with the reference numbers and names and part numbers of each below the picture.
The only problem you are going to have is that it is so old that Sears has discontinued nearly all parts in the listings
Nov 03, 2009 | Garden
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
Blade gone south (shreader)
www.gopresto.com you can order parts here!
Please rate this FREE response!
Dec 07, 2008 | Presto SaladShooter Plus Food Processor
The shredder runs perfectley in the reverse direction, but does not run at all in the shredding direction
I have seen many shreaders that are caked with paper underneath the blades.
After you remove the power, turn the shreader upside down (if possible )and completely clean the area.
Make sure you use shreader oil after you clean it
Dec 01, 2008 | Office Equipment & Supplies
100 people viewed this question
k24674
jasbo
jasbo
