Question about Kyocera FS-C5015N Laser Printer
It is only printing black pages, have replaced all the toners and emptied the toner box... not quite sure how to fix it?!
  • admin65 Sep 15, 2010
    I did try that before, tried it again and it worked! Guess i didnt shake it hard enough.
    Thank you very much for your help!!! :)
    President:
  • 4,070 Answers
Hi! You may start on shaking the toner first before installation. This can help. Have a good one and thank you for using FixYa!
Posted on Sep 15, 2010
  • dj_relly999
    dj_relly999 Sep 15, 2010
    No problem. Have a good one!
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
I emptied the toner waste container on my Samsung CLX-6260 FD printer. Now all prints are completely black. Any suggestions on how to fix?
emptying the waste box is not recommended but should not cause solid black prints. solid black prints indicate a problem with the image formation, primary or secondary transfer, or laser units. reset all toners and make sure the toner rack is slid in fully.
Dec 28, 2015 | Samsung Office Equipment & Supplies
How do I know which toner is empty on samsung clp315
  • 1.Log on to your computer and print a test page to the printer. Click on the "Start" button, choose "Control Panel" and then "Printers and Faxes." Right-click on the laser printer, choose "Properties" from the drop-down menu and click the "Print test page" box.
  • 2.Look at the quality of the print on the finished page. If the print is light or faded, the ink cartridge is probably empty or at least empty enough that it should be replaced. You can try to get some extra life out of your toner cartridge by taking it out of the printer, shaking it vigorously and putting it back in. Under normal printing loads, this can give you one to three days of additional printing capacity.
  • 3.Open the printer cover and carefully pull out the toner cartridge. Set the cartridge aside while you open the box containing the new toner. Pull the new toner out but do not yet remove any of the packaging materials. Compare the weight of the new toner with the old one. If the old toner is very light, it is nearly empty and should be replaced.
  • Sep 22, 2011 | Samsung CLP 315 Laser Printer
    My canon printer ir 2022 prints faint and blank pages, what can be a problem and how can i fix it?
    Possible Problems:
    1)Out of / Low on Ink.
    Solution : replace the ink
    2)Printer Setting
    Solution : Check to make sure the lighter/darker slider is somewhere near the middle. This will be in the configuration screen on your printer.
    May 02, 2011 | Canon iR 2022 Printer
    Is there a override function to keep printing when toner alerts are on?Wondering since black still shows 30%.
    These printers will still print when any or all of the toners are LOW, but if any one of them is EMPTY (according to the chip on the toner cartridge) printing stops.
    Standard capacity toners ere 2000 page for the colours, and 3000 page for the black, so they can soon be used up.
    Much cheaper per page printed, if you use the high capacity cartridges (6000 page for the colours, and 8000 page black).
    There are high quality remanufactured cartridges available now, as good as OEM, and typically you'll get a Hi Capacity Remanufactured cartridge for the same sort of price as a Std Capacity OEM cartridge.
    As a short term solution at a lower cost than replacement cartridges, you could just replace the cartridge CHIP. The printer would then think the toner was full (there'll likely to still be some toner in it), so you'll be able to print. Don't run the printer like this for ever though, as the toner has some lubricant properties, and with a TRULY EMPTY cartridge, you'll eventually do some damage to the cartridge, and then possibly the transfer belt (and you don't want to be changing that until it's rated 100,000 page life is up.
    May 01, 2009 | Xerox Phaser™ 6180DN Laser Printer
    Black marks on my paper when I print
    Replace the toner with new one. because It's problem of toner drum (It's in blue or green colour).
    Dec 08, 2008 | HP Color LaserJet 3500 Printer
    Brother 9440cn replace toner message override
    well you could shake the toner cartridge, to make sure that the remaining toner has uniform coverage to the developer roller, which is the black magentic roller in the toner, which applies the toner onto the drum.
    Only way to fix, if the printer uses a electronic sensor, is to actually change the toner, it can not be overridden.
    Nov 28, 2008 | Brother HL-2040 Laser Printer
    Color toners are empty
    Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
    Dan :-)
    Sep 30, 2008 | HP Color LaserJet 2600n Printer
    Out of toner........ but not really.....
    Print a Supplies Status page to see the actual pages printed...
    To print the Supplies Status page from the printer, on the printer control panel, select
    Reports Menu, Supplies Status, and then Print Supplies Status page.
    If the page count from the Supplies Status page indicates that the toner should not be in need of replacement then you have a bad cartridge. Actually, the cartridge is probably fine but the chip on the cartridge has got a problem. Return the cartridge to O.D. and get another one. Unfortunately, chips that don't work properly in not all that unusual so HP has a pretty easy return policy.
    Hope this helps.
    Mar 07, 2008 | HP Color LaserJet 2600n Printer
    Toner Empty Message won't go off
    check that the toner is inserted correctly, reboot print.
    Aug 27, 2007 | Konica Minolta magicolor 2430 DL Laser...
    Kyocera FS-C5015N Laser Printer Logo
    60 people viewed this question
    Top Kyocera Office Equipment & Supplies Experts
    Kyocera HP Expert
    CheckitRight
    CheckitRight
    Henry Gertcher
    Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
