Question about Cambridge Audio Azur 540R Receiver
Cambridge Audio 540R Azur V1- Automatic DSP change
Hi folks, I'll be using the AV receiver in subject for a couple of days now. The problem with it is that it changes DSP mode automatically. I've got just two speakers so I set it to play "Stereo" but the every few minutes it changes the configuration to "CINEMA" or "MUSIC" DSP profile . This is particularly annoying because the CINEMA profile send all mid freqs to the centre speaker that I don't have! I've opened the beast and there isn't anything "clearly" wrong with it. Any idea how to proceed? I tried the DIY approach because the unit is out of warranty and I bought it second hand. Cheers Marco
3 Suggested Answers
SOURCE: Protection overload and the system shuts off
Check if one of the speakers are damaged
Posted on Jan 13, 2010
SOURCE: I have an audio azur 540r receiver. My problem is
I have the same problem. It always happens when the I put the music louder
Posted on Dec 27, 2010
Cambridge azur 540r receiver just stopped working. no power showing to on/off led.
Could have a problem in the power supply section. Check for open diodes and bad capacitors.
Sep 27, 2015 | Cambridge Audio Azur 540R Receiver
Cambridge Audio Azur 640R AV Recorder won't switch off
Sounds like the unit is victim of a power surge. The power control board is probably damaged. You will be better off replacing the amp as having it repaired will cost more than replacing it.
Mar 02, 2014 | Cambridge Audio Azur 640R 7.1 Channel...
I have a cambridge audio Azure 540R. WAs all working fine. A red box with SW under the L speaker channel has appeared. No sound from the L speaker, Although the test sound through the L channel is ok. The...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Cambridge-Audio-540R-Receivers-review-manual/id/2536dj197/t/1-2/
"SW" stands for SubWoofer.
Page 8...
Shows the currently active channels depending on decoding mode and source material. Icons lit indicate active channels in the source material. Icons with a box around them indicate actual channels being output separately.
Search for the word "balance". Page 8 again (circled 8)...
Lights when the Front Left and Right speaker outputs have been set to different levels in the OSD, i.e. a balance adjustment has been made.
You can look at the relative levels of all channels as described on Page 14.
Mar 22, 2011 | Cambridge Audio Azur 540R Receiver
I have tuner AUDIO CAMBRIDGE 640T NOT AMPLIFIER!!! PLEASE ASK GURU!!!!!!I
The question is - what can cause the problem seen on the photo below? CA Azur 640T - shows only the symbols after switching it on.
Feb 06, 2011 | Cambridge Audio Azur 640T Receiver
Very loud noise coming from amp as soon as amp is turned on..noise will not fluctuate with the volume..noise stays constant?
This will be the large Electrolytic Capacitors in the Power Supply. You can't miss them. They will over 4700uf or around that in value. Replace them all, even if only one has gone. I think what your hearing is the 50/HZ hum from the mains getting in.
Jan 12, 2011 | Cambridge Audio Azur 540R Amplifier
Reasons: 1. Short in the wire, speaker, or amplifier 2. Amplifier malfunction 3. Overload of the amplifier 4. Overload of the speaker
Listening to audio at loud levels requires more power obviously. But the speakers and amplifier may not be rated or capable to handle it due to age or design.
Jan 13, 2010 | Cambridge Audio Azur 540R Receiver
check your speaker wires for short, try to turn it on without speakers connected, if all connections and speakers seem ok the problem is internal witch can go from blown power supply to shorted output devices and everything in between , and as always look for repair shop in your area, do not attempt to do it yourself, fire hazard and electric shock are the things we all want to avoid ;)
Sep 02, 2009 | Cambridge Audio Azur 540R Receiver
When put in stero mode,the speakers blast out at full volume..
I had the same problem and have solved it bij resetting it.
Try the small hole above the powerswitch.
Good luck.
Oct 30, 2008 | Cambridge Audio Azur 540R Receiver
Cambridge Audio Azur 540R Receiver Logo
889 people viewed this question
Top Cambridge Audio Players & Recorders Experts
Don Hart
Tom Chichester
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Cambridge Audio Player and Recorder Expert? Answer questions, earn points and help others
