Question about Goodman CLT48AER48 Air Conditioner
Central AC comes on but won't stay on. Could it be low on coolant?
  • Goodman Master
  • 1,144 Answers
This is possible only if there is a Low Pressure Switch on the unit. Most residential units do not have those but it is possible. I'd look else where, such as thermostat for starters.
Posted on Sep 15, 2010
Need input on engine code for engine temp staying low too long
Have you not googled your obd codes
& diagnosed them, to find a problem
No idea why you would do all you did
You always resolve code related issues first
The coolant temp should be 210 all the time
Sounds like your not looking at scan tool data
or following any factory trouble charts or actually
know what coolant temp is,your just assuming & not
doing the required testing to verify things
Nov 21, 2014 | Jeep Cars & Trucks
Acadia white smoke, high temp and fan won't come on
Do you have an extended warranty ?
Usually white smoke from the exhaust means the engine is burning coolant thru a blown head gasket or intake gasket.
You should also be low on coolant in the radiator.
Apr 30, 2013 | 2008 GMC Acadia
HOW TO ADD FREON TO ac
go to local auto zone and buy coolant....open hood and you should see two valves with maybe caps on them ,these are your valves. Now dont bother as to which one you need for coolant will only fit the right one..connect can of coolant to valve and start car up and turn AC on. Be sure to open valve on can of coolant....most cans you have to close completely as to puncher opening in can then open valve and coolant will inject into AC system....
Aug 18, 2012 | 2003 Toyota Matrix
Ac won't come on
Poss low system refrigerant charge.
May 24, 2012 | 2003 Mercedes-Benz S-Class
Code 3 insignia low coolant
Add coolant. Find the leak and repair it. You won't have heat when the coolant is low.
Feb 18, 2012 | Cars & Trucks
1998 grand prix gtp stalls when coming to a stop and low coolant light stays on but car does not run hot.
Stalls when coming to a stop- have idle control motor checked as this may possibly be the cause.
Low coolant light stays on- there is a low coolant sensor located on the radiator on the passenger side. They are known to go bad on these models, this is a possible cause. Have your mechanic take a look at it.
Aug 31, 2011 | Pontiac Grand Prix Cars & Trucks
I have a 2008 Town and Country and the temp gage gets to dead center and I smell antifreeze. Never remember the gage ever reaching the center before either. So I Checked to see if the radiator cooling fan...
ok this might sound crazy but you say you smell coolant but never said if you checked to see if it was full posible bad coolant temp sensor or no coolant passing the sensor please more info on coolant usually if low coolant fan will stay on however you say you smell coolant. If the coolant sensor is bad fan wont command on it will have a high resistance a low coolant temps and low at high temps. I would check sensor since its obviously getting hotter than half way if you dont have coolant leak the relay behind the head light by the way is a common problem I would have just changed it if its original and it grounds to body thats why it is riveted however you can bolt them. Hope this helps check for thermostat opening at right temps to.
Jan 07, 2011 | 2008 Chrysler Town & Country
My 2003 vw bug dies and won"t start when i run the ac on very hot days. sometimes when i"m driving all the instrument panel lights all come on ant then it loses power to aprox 5 mph. I checked the...
ENGINE GETTING TOO HOT AC PUTS MORE LOAD ON ENGINE AND OUT SIDE TEMPERATURE HOT.YOUR CAR TELLING YOU I AM HOT AND NEED A BREAK.MAKE SURE COOLANT LEVEL NOT LOW AND THE COOLING FANS RUNNING WHEN AC GOING IF NOT CHECK FAN FUSE IF FUSE GOOD.YOUR THERMO SWITCH NOT WORKING OR THE COOLANT TEMPERATURE SENSOR AND FAN CONTROL MODULE COULD BE THE PROBLEM IF THE FANS DONT TURN ON.
Jul 15, 2010 | 2001 Volkswagen Beetle
2003 Suzuki XL7 A/C won't stay on
The low pressure is in the grill by the radiator. The issue your having with it cutting off then on is easily fixed by removing some of the AC coolant. Any ideas on why the rear AC is not working? Is there a seperate fuse for the rear AC? It just blows warm air.
Mar 20, 2009 | 2005 Suzuki XL-7
Low Coolant light stays on
Check you coolant resevoir. The low coolant switch is located in the resevoir so if it is low on coolant there, the light will come on. If it is full, it could be that the switch is stuck due to gunk build up in the resevoir. Hope this helps you out
Jan 19, 2009 | 1993 Chevrolet Beretta
Goodman CLT48AER48 Air Conditioner Logo
52 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
