Question about HP Officejet 5610 All-In-One InkJet Printer
My HP printer says it is installed but it won't print when I send something to the print page? Can you help?
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Without knowing the specifics of your operating system or what happens when you click print (error message, operating system, etc.) I'd suggest this general fix.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02114788&cc=us&lc=en&dlc=en&product=441125
Posted on Sep 15, 2010
My HP CP2025 printer will not print color text and color shading in Word. It prints color photos, pdfs, and paintbrush files, but will not print color in Word or Word Perfect.
I had this problem on Windows 7 64x.
The solution that finally worked for me:
1. Go to your Devices & Printers window. (from the Start menu)
2. Right-click on your HP CP2025 printer and select Printer Properties.
3. Select the Device Settings tab.
4. Scroll to the bottom where you see Device Type. It probably says "Auto Detect."
5. Click on the words "Auto Detect" to activate a drop-down menu. Select "Color". Click the Apply button.
To test if this fixes your color printing, go to the General tab and click the Print Test Page button at the bottom. The page should print the Windows logo in color at the top of the page (the rest of the page is b&w).
Note: I did not install any additional drivers from HP for this printer. Windows automatically detected it and installed HP's Universal Print Driver PCL 6.
Kudos to Ken from the HP forums for this knowledge: http://h30499.www3.hp.com/t5/Printers-LaserJet/CP2025-Won-t-Print-in-Color/td-p/1151762
Feb 10, 2011 | Office Equipment & Supplies
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
I've reloaded drivers, it prints out test page fine. When sending others like web pages etc it sends blank pages through with some charachters on them
Certain web pages require a Postscript driver, not a PCL driver. HP printers usually can do both. You can check this by going into properties for the printer (right-click), go under advanced, and check the driver file. Go to the HP website and make sure that if it gives a choice, that you got the right one. Also make sure you are not using a 64-bit driver on a 32-bit system. This can give you limited or no functionality. Their are also some pages that just don't print from the Internet, that is why the pages often have print friendly links. Make sure this is not the case by printing something you know should print, like a Word document or a picture.
Nov 08, 2009 | HP PSC 2175 All-In-One InkJet Printer
My HP 1410 Printer Scanner won't print.only prints tiny hyroglyph
That means that the software driver must be re-installed.
Before starting driver setup unplug printer usb, the software installer will tell you when to connect the printer.
If you are using Vista , also start driver setup by clicking right button of mouse on installer file and chosing 'run as administrator'.
Here the download pages, you can also get manual and support links in there:
HP PSC 1410 All-in-One Printer
Select software and drivers
Click on page below and follow instructions to download the driver.
Apr 10, 2009 | HP PSC 1410 All-In-One InkJet Printer
HP laserJet 5000 Printer continually printing same page
laserjet 5000 printer A4 size printing right side line not printing .why?
Jan 14, 2009 | HP LaserJet 5000 Printer
Printer Problem
HI!. Most printers have a self test facility to do a test page without being connected to any PC. If you can find that out from the HP site, that's a first step. Also, check printers in Windows Control Panel to make sure it is the "Default" printer. Try to send a test page. e.g. right click on the icon for the printer, select 'properties' & look for "Print test page". If all these work then next you would open Windows notepad and just type in a couple of rows of text, then print. If that works, then you try your original application program to prove that it is the cause (somehow). Check all physical connections & re-load the s/w driver.
Also, you could take your printer to a friends place that has the same Windows OS and see if it installs OK. Try & test print etc.
Hope this helps you to narrow down the problem.
Jan 06, 2009 | HP DeskJet 890c InkJet Printer
HP 1410v will not print.
The printer is printing an alignment page. Take that alignment page and put it on the scanner part of the printer and then press the scan button, that will align the print heads
Nov 12, 2008 | HP PSC1410 Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
Printer prints test page each time printer is turned on
There may be something initialised to print a test page everytime it starts, just remove printer, uninstall driver and re start. Re install drivers and connect printer when prompted or when installation has finished. This should revert to default settings.
Jan 07, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
