Question about Acer Aspire 5600 Series 5630-6951 Laptop
I have a Acer Aspire 5600 laptop This laptop does power on with a good battery and with an ac adapter but sometimes it takes awhile for the video to appear on the screen & sometimes it will restart itself or just go black. is the motherboard is bad or something to do with the fan?
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
AC adapter 4750z
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
Acer Aspire 9110 problem
Sounds like your video is bad or the laptop is not getting power from the ac adapter or battery. Make sure your ac adapter power cord is good.
Mar 27, 2012 | Computers & Internet
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Ummm, hi. i was wondering how many watt my Acer Aspire 5600 runs?
Power
subsystem
ACPI 2.0 CPU power management standard: supports
Standby and Hibernation power-saving modes
71 W 8-cell or 44.4 W 6-cell Li-ion battery pack
Acer QuicCharge™ technology
(for Aspire 5600 Series):
• 80% charge in 1 hour
• 2-hour rapid charge system-off
• 2.5-hour charge-in-use
90/65 W AC adapter
Oct 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Battery
Nothing to worry about mostly all the laptops do this,
Sep 10, 2008 | Acer Aspire 3680 Laptop
Wireless not working when ac adapter plugged in
It looks like you've changed the settings to turn off the wireless when AC adapter is preset. Try going into Acer Power Management and make sure Wireless Lan is selected on your Power Plan.
-Aaron
Aug 06, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5600
You still need to test the AC cord better.. Wiggling it in different areas to see if there is a break in the wires.... That is why i said watch for the Power light (when I say Power Light, not the one on the ac adapter cord... the power light on your laptop...)to see if it flickers or turns off at any point while you're testing the cord... If you have a Solid Lighted Power Light the whole time youre testing the AC cord (bending & wiggling it) then it is probably not the cord itself and i would then lean towards the DC jack...
Jun 04, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Laptop was working fine, but doesn't turn on anymore...
a5e3d98.jpg You might have a Loose DC Power Jack.. Or.. if you're using the same AC Power cord for both laptops that you tested, you apparently have a break(short) in the Power charging cord which is quite common...
To Test the cord..take the battery out and try to boot with just the AC power cord plugged in, If it does'nt power up, try turning and slightly twisting the plug into the port.. LOOK to see if the power light is on or flickers...
Acer Aspire 5600 Series 5630-6951 Laptop Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
