Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
I have a problem with me HP M1522nf printer, fax copier. I read one of the solutions but not sure how to update the firmware. Can some one tell me how I go about doing this. I cleared the machine and it still tells me the memory is full so I think I need to upgrade the firmware. P
Its not that difficult, first do you print to this machine? If you do then this will be easier, if you don't then you will need to add this machine as a printer to your PC. Go to HP.com and click Support and Drivers, check download drivers and software. Enter the product number off of the metal plate (on the back of your printer) It will be something like CB543A. This will give you a couple of options choose the printer that you have, select your operation system, scroll down to firmware and download. This is an executable file which means when you "RUN" this product it will send it to the printer. It will give you a prompt to select the printer, select the printer you want to upgrade. hit send firmware. It may take a while on the printer side, don't shut off until it says to. After it finishes cycle power and print a configuration page to make sure it is upgraded..
Posted on Sep 21, 2010
HP LaserJet M1522nf Multifunction Printer (CC372A)not working /driver is not updating. How to reinstrall the firmware for the printer
updating the firmware will require you to 'LOG' into the machine via the web browser ( enter the printers IP address into the address bar and wait until the internal web page is displayed) select the advanced/upgrade/migrate tab and browse to the firmware file you should have downloaded and saved to your hard drive. here is a link to the web page containing the firmware file for your printer---
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/upgradeMigrateResults/?sp4ts.oid=3442750&spf_p.tpst=psiContentResults&spf_p.prp_psiContentResults=wsrp-navigationalState%3Daction%253Ddoclist%257Ccontentid%253DK.05.05&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
the latest drivers can also be found here ( manufacturer Drivers/ firmware)
hope this helps
Jan 28, 2014 | HP LaserJet M1522nf Multifunction Printer...
Hp Laserjet M1522nf . my folt i am load 3020 firmware . how to solve this problem. my email id --sarif.sk14@gmail.com
can you tell me you loaded firmware or driver coz they wont accept old or different firmware if you did you need to re install original firmware frim disk (if its in disk ) or download
Jun 23, 2011 | HP LaserJet M1522nf Multifunction Printer...
We have a M2727 Laserjet Printer/Fax . We can print, and we can receive fax, but our problem is sending a FAX.. Keeps giving us an error code of 49. Please advise Thank-You, Marla
I found this on the HP website:
HP LaserJet M2727 Multifunction Printer Series - 49 Error Message Is Displayed While Faxing ISSUE: The printer control panel will be displaying 49 service error while sending faxes. The receiving fax will be lost, and the printer will display the same error even after reboot. SOLUTION: Performing a factory reset and a firmware upgrade is the only solution for this issue. Step 1: Performing a factory reset Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number. CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product. Perform the following steps to restore the factory-set defaults: 1. On the product control panel, press Setup . 2. Use the arrow buttons to select Service , and then press OK . 3. Use the arrow buttons to select Restore defaults , and then press OK . The product automatically restarts. Step 2: Firmware upgrade After coming to ready, upgrade the printer firmware from the HP website. The issue can be fixed with any of the firmware upgrade available now. Firmware version 20080505 and higher versions have the fix. You can download firmware version 20080612 from the HP LaserJet M2727 Firmware Update 20080612 webpage. Click here to go to the HP LaserJet M2727 Firmware Update 20080612 webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&swItem=ma-55531-3&prodNameId=3377076&swEnvOID=228&swLang=8&taskId=135&mode=4&idx=3) . The preceding steps will resolve the issue.
Mar 07, 2011 | HP Office Equipment & Supplies
My hp laserjet M1522nf is showing Firmware corrupt ready 2 download
You need to connect the unit via USB and then run the HP firmware update utility so that the current firmware can be installed. This error is usually caused when a firmware update is interrupted. Current firmware for this unit is 20100902.
Feb 22, 2011 | HP LaserJet M1522nf Multifunction Printer...
How do i receive fax
Here is the link to HP Official Support site. You can download the User Manual for HP LASERJET M1522 NF MFP Printer. Go to Section 10- Fax (Page 69) for complete and step-by-step instruction for setting up fax.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 06, 2010 | HP LaserJet M1522nf Multifunction Printer...
I get an error 49 message as soon as I try to fax. Then the printer switches itself off and back on again.
Try the following: got to the menu (the wrench) and with the arrows look for service, press ok and look for restore defaults. After that unplug the fax line (this is very important). Go to the hp website and download the firmware update and run it (while updating dont to anything to the printer, no print, copy, fax.) when that is completed try to fax again this should resolve it. If the error persist the formatter (the motherboard) is defective. I think HP repair formatter issues with 2 years from the original purchase.
Sep 07, 2010 | HP LaserJet M1522nf Multifunction Printer...
I cannot Fax in and out...error 49 turn off and on. After i turn on the printer another error show that "power failed to recover Fax setting restore"....please Help~
Jul 25, 2010 | HP LaserJet M1522nf Multifunction Printer...
When i start my printer hp m1522nf mfp printer ,its shown me the erorr your firmware is curropt
Turn the printer off, hook up the USB cable and try making a firmware update, you can find the file for making the firmware update from support and drivers section under www.hp.com, finally turn the printer back on
If this does not fix the problem means that the formatter board is damaged, call 1800 334 51 44 (hp tech support)
Mar 04, 2010 | HP LaserJet M1522nf Multifunction Printer...
How to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Dec 13, 2008 | HP LaserJet M1522nf Multifunction Printer...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
226 people viewed this question
Seeker5211
Seeker5211
