Question about HP LaserJet 3030 All-In-One Printer
Scanner problem when i on my printer it gives an error Scanner power on off
  • Anonymous Jul 18, 2008
    Scanner not work
  • kishanraipur Jul 18, 2008
    scanner not work, fax incoming working, fax outgoing working
    and printing working, coping not working
    massege shown scanner error power on off
  • 96 Answers
Reinstall the software and try to check if there is paper jump. Then try to check if there is lost connection inside the power supply and the chords.
Posted on Jun 05, 2008
Show error 52.00
52.X PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Apr 16, 2016 | HP LaserJet 4350n Printer
How can i fix This Issue?
Try this: 1) With the printer turned on, unplug it from the main power supply, then press the power button for 30 seconds or so.
Power back on and see.
If doesn't work,
2) Clean the glass and white background material
If that doesn't work,
3) check the scanner bulb assembly: is it able to move freely? Also, the scanner bulb may need replacing.
Experience: I had an HP printer giving the same problem. I was encouraged to buy another printer by support team (scanner bulbs may not be sold just like that). I got another printer not working at all (different make) and used the bulb from that one and I stopped getting the error and printer worked perfectly.
If you can get a similar scanner assembly - preferably for the same make, then do so.
Sep 09, 2014 | HP Laserjet Pro 400 Mfp M425dn...
Scanner Error - Power On Power Off
The "scanner warming up" error is usually caused by dirty glass or mirrors in the scanner assembly. Here is a link to a step by step guide that tells how to open the scanner unit and clean the optics to clear the error.
http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/
Feb 28, 2013 | HP LaserJet 3300 All-In-One Printer
Hpm1522nf - scanner error 8
Replace Optical Scanner Assembly(CCD).. Some technical knolwdge required to replace this part.. See the part:
Jan 08, 2013 | HP LaserJet M1522nf Multifunction Printer...
Scanner gives me code 5,145,61 how can fix it ?
RE: Scanner gives me code 5,145,61 how can fix it ?
I was using wireless router and receive exactly the same error code as above.
SOLUTION: Turn-off printer/scanner; reset or turn-off the wireless router power and then turn-on again. Turn-on the scanner. Start scanning.
Mar 11, 2012 | Canon PIXMA MP495 InkJet Printer
Please give explanation & soulation hp laser jet 3055 scanner error 6 \r\nWhy this problem are create in our printer
Scanner error #6 = DocOriginFind
Per the service manual here are the steps:
1 - Power Cycle the Machine (I'm sure you've done this already)
2 - Replace the Scanner Assembly (After replacing this if the message still appears then.. )
3 - Replace the Formatter and Line Interface Unit (LIU)
Oct 20, 2010 | HP LaserJet 3055 All-In-One Printer
HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Sep 23, 2009 | HP LaserJet 3030 All-In-One Printer
Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3030 All-In-One Printer Logo
119 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
