Question about GPS
How do I replace the GPS cd in a 2002 ls 430 - GPS
  • 1 more comment
  • cmmosr Sep 15, 2010
    Sorry! Lexus LS 430 ,2002
    I have purchased the CD from the Lexus dealer. My lexus is a 2002. Does this info apply to this year as well?
    very helpful. I will use you again in the future.
    Top Expert:
  • GPS Master
  • 80,562 Answers
430 what?
Posted on Sep 15, 2010
  • 4 more comments
  • yadayada
    yadayada Sep 15, 2010
    The Right DVD
    It is imperative the you obtain the correct replacement DVD for your particular Lexus model. There are plenty of articles on this so I won't belabor it in this article. The easiest way to just go is asking your Lexus dealer parts department for the updated DVD for the navigation system that matches your year and model. The 2004 LS430 is a "GEN4" system. The current version as of this article was 2007 version 1. My old version was 2004 version 2.
    Location
    The DVD based navigation system is located in the trunk under the mat on the passenger side of the vehicle. It is securely mounted under the mat and deck. It is about the size and shape of a self enclosed after-market radio. It sole purpose is to provide the Navigation information for the vehicle.
    STEP 1.[/b]
    Remove the trunk mat completely from the vehicle and set aside. Lift the decking using the handle exposing the spare tire. Completely remove from the vehicle and set aside.
    STEP 2
    Remove the deck mounting tack using a small bladed screwdriver and lift up. Set aside for replacement. Remove the side decking exposing the DVD unit.
    STEP 3
    The DVD unit is mounted securely in place using 2 bolts on either side. Both of these must be removed using an 8mm socket or a Philips screwdriver. Set the aside for re-installation. (Be careful not to drop them down into the cavities surrounding the unit. It looks dark down there and you might not get them back)
    STEP 4.[/b]
    Carefully lift the front edge of the DVD unit up from its holder about 1".
    DO NOT REMOVE THE UNIT COMPLETELY.
    [b]STEP 5
    START THE VEHICLE. It must be running to provide power to the unit. Remove the old DVD from the unit using the OPEN button by pushing in and sliding to the left. This will reject the old DVD currently installed in the unit. The Navigation screen will display a message indicating there is not disk installed. Insert the new updated DVD into the slot on the unit. Slide the OPEN button back to the right into its original position. The navigation screen will display a message indicating the system is loading the new data.
    [b]STEP 6
    • Carefully push the unit back down in its mount. Replace the 2 bolts
    • Replace the side deck and mounting tack
    • Replace
  • yadayada
    if u can afford this i highly recommend the dealer do this upgrade!
  • yadayada
    This is the correct procedure, it comes from the factory manual, please rate my help..
    I do not enjoy working with my dealer. I would prefer to do this my self if possable
  • yadayada
    then follow the procedure, but follow it to the letter, why the attitude with the dealer?
    Thank you very much. I will follow your instructions and hope it works. I will let you know
    Your help has been excellent. A10
Where is the horn relay for a 2002 LS 430 Lexus located?
CHECK IT AND THE PASSENGER COMPARTMENT..YOU CAN FIND IT THERE.
Aug 12, 2017 | 2002 Lexus LS 430
When do I need to change transmission fluid on my Lexus LS 430 (2002)?
Under normal driving conditions, Lexus recommends not changing the fluid until 150,000 miles.
Feb 10, 2011 | 2002 Lexus LS 430
My battery went dead in the lexus ls 430 2002, and the system shut down, anybody no how much this would cost at the dealer
charge battery then start it up sounds like alternator i used to own that car prob 500
Aug 20, 2010 | 2002 Lexus LS 430
How do you change the air condition filter on a 2002 lexus 430
It is behind the glove box. It is simple to replace, just remove the glove box (squeeze sides until it opens all the way down), open the little door and slide out the filter.
May 11, 2010 | 2002 Lexus LS 430
Lexus battery
JUST USE THERE BATTERY APPLICATION CATALOG TO SELECT THE CORRECT SIZE FOR YOUR LEXUS, U DON'T HAVE TO USE THE MORE EXPENSIVE FACTORY BATTERY, IN MOST CASES IT IS A WASTE OF MONEY.
Apr 20, 2009 | 2002 Lexus LS 430
6 year old battery
always put the black (ground) on first and disconnect it last.
Nov 14, 2008 | 2006 Lexus Ls 430
I lost my instruction manual on my navigation system.
I own a 2002 lexus LS 430 with navigation system. The radio plays, but the volume and function on cd player does not work. The volume is real low and cant be turned up at all.
Jul 22, 2008 | 2002 Lexus LS 430
GPS Logo
201 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
