Question about Toshiba Tecra M4 Tablet PC
System Crash My laptop crashed I have tried to recover it using the Recovery dvd that came with it but it stops midway and goes back to the screen that just has the letter a all over it
    Genius:
  • 2,785 Answers
Do a clean installation
Posted on May 16, 2008
I can no longer access Candy Crsh. I tap the app and when I tap play the screen blanks out and goes back to the home page.
So Candy Crush has become Candy Crash :>) You need to delete the app and download it again after rebooting. You will probably lose your game level history.
I have never played the game, but if you get updates to the App? You might want until a new version comes out and fixes the crash bug. You can also go to the App Store and report the bug on the Candy Crush page. Good job it is ONLY a GAME eh?
Dec 24, 2016 | Tablets & eReaders
How to reset a factory fasttouch 7inch tablet
Hard reset or factory wipe is a method of formatting any Android device ( tablet or mobile). By doing hard reset all the apps and files that are installed or created by the user will deleted. Even the memory card will get formatted. So before going for hard reset or factory swipe, it is suggested to remove the memory card if you do not want data to be erased
For simple factory reset the process is follows:
Sponsored
  • Goto settings -> Back & reset -> factory data reset
After factory reset, only pre installed apps and files that came with the device will remain on it.
Feb 19, 2015 | Android 7 inch Tablet
Archos problem
Help, my Archos A70h is stuck on recovery the white page, it won't boot, how can I get back to the home screen.
May 15, 2013 | Archos 70 - 250 GB Internet Tablet
Message missing operating system
This sounds like the main partition on your harddrive was corrupt. You will need to reformat the system.
Using the Recovery Partition:
1. Press [F9] during bootup.
2. Press [Enter] to select Windows Setup [EMS Enabled].
3. Select the language you want to recover and click
Next.
4. Read the ASUS Preload Wizard messages and click
Next.
5. Select a partition option and click
Next. Partition options:
Recover Windows to first partition only.
This option deletes only the first partition and allows you to keep other
partitions, and to create a new system partition as drive "C".
Recover Windows to entire HD.
This option deletes all partitions from your hard disk drive and creates
Recover Windows to entire HD with two partitionThis option deletes all partitions from your hard drive and creates two
new partitions "C" (25%) and "D" (75%).
6. Follow the onscreen instructions to complete the recovery
process.
Make sure to burn off your recovery DVDs as soon as you get you rsystem back up and running so that you have them in an emergency.
Feb 28, 2013 | ASUS X53U-RH11 New
Toshiba tablet R15-S829 has only c drive .can i do partition in this hard drive. is it accptable for this laptop or not.please help
I think the problem is only that your system crashed. So you can try some data recovery software to recover the wanted data from system partition and then reinstall OS,
I suggest you can use a free data backup software to create a recover disc once you enconter such a problem you can recover your data and system easily.
Freeware AOMEI Data Backuper: http://www.aomeitech.com/aomei-data-backuper.html
Jan 22, 2013 | Tablets & eReaders
Android tablet screen freezes
I have an apple android tablet and it freezes at the android with black backround
Jan 26, 2012 | Tablets & eReaders
Forgot password, does not have cd rom drive, need to restore to factory settings. How???
How to obtain Vista Recovery Media and/or use the Vista Recovery Partition on your computer to put it back to Factory Settings.
There is no legal free Vista download available.
Contact your Computer Manufacturer and ask them to send you a set of Vista Recovery disk/s.
They normally do that for a small $ cost.
Also, ask them if you have a Recovery Partition on your Computer/Laptop to restore it to Factory settings.
See if a Manual came with the computer, or go to the Manufacturer's website, email or phone them for info on how to do a Recovery.
Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash.
They will tell you how to do that.
Each Computer Manufacturer has their own way of making Recovery Disk/s.
Or borrow a proper Microsoft Vista DVD(not Dell, HP, etc).
A proper Vista DVD contains all Vista versions.
The Product Key determines which Vista version gets installed.
There are 2 Vista disks: one for 32bit Operating System, and one for 64bit Operating System.
If a clean install is required with a proper Vista DVD (not HP, Dell Recovery Disks):
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
http://support.microsoft.com/default.aspx/kb/918884
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
http://www.winsupersite.com/showcase/winvista_install_03.asp
Windows Vista Installation Super Guide
After installation > Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
Save all Data, as it will be lost during a clean install.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 09, 2011 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Trouble booting!
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Jan 08, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
ASUS F3S startup problems...
Have you tried doing a system recovery using the "hot" keys for the machine. Contact ASUS support for the instructions.
Apr 11, 2017 | ASUS R1E-B1 Tablet PC
Toshiba Tecra M4 Tablet PC Logo
100 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
