Question about Xerox 5855C Copier
Error code 11-346 on xerox 5855c - Xerox 5855C Copier
  • 239 Answers
This machine must have a stapler and a sorter.
Most common problem to fix it is to replace the main board inside the sorter.
Other problems are the sorter needs to be latched correctly so the actuator (steel pin) can actuate the closed interlock switch.
This sorter is usually pretty realiable, when a problem occurs, then it is really big problems. This would require the schematic to locate the other power circit boards to see where the sorter lost power.
Other possible problems can be an old NVM battery on the main board. (Date on the chip over 10 years old) When the battery is not good, this causes memory corruption to the values, machine setup configuration. The memory gets corrupted causing the machine to malfuntion.
Not seeing the machine, it is difficult to further trobleshoot the problem.
Posted on Nov 04, 2010
Xerox WC 5330 error Code 010 338
I think it is a toner or maybe paper issue, as a first step I would remove and re install both
Jul 13, 2016 | Xerox WorkCentre 5330/P Printer
FUJI XEROX 016 757 ERROR CODE
Could be: The entered password is wrong or
Auditron security (A Xerox feature) is preventing users from Printing.
Then: Enter the correct password (Default 11111) or
Disable Auditron security settings from the Administrator menu.
Xerox Error Code 016 757 Tech on Tour
http://es.scribd.com/doc/21054313/Fault-Codes-Xerox
http://arts.ucalgary.ca/it/kb/221/xerox-printer-giving-016-757-error
Jun 25, 2014 | Dell 3100cn Laser Printer
Xerox 5855copier showing 03-326
Try cleaning the optics even if they seem to be clean
Apr 08, 2010 | Xerox 5855C Copier
My xerox 58855 copier is showing fault code 03-326 please help. my email adress is mupetaclifford2005@yahoo.com. i will be very helpy if i will be helped
I am not sure I answered this question before, because I do not see the response I put in one of these for this problem.
This code 3-326 is not an easy problem to repair.
For simple repairs, one would take off the rear covers and disconnect any plug on a circuit bord and plug it back on. This would reseat the plugs for some loose pin connections or some pins not contacting very good. This is true especially with the pink wires, the 5 volt lines.
Another problem might be the low voltage power supply, its expensive if you need to replace it. Also the large high voltage power supply. These two can go bad when one of the voltages go out.
From here, these types of codes can be hidden errors. If the exposure setting is off, the machine will shut off and the exposure needs to be recalibrated. You need a service manual to do that and some expert knowlege to do it. There are many areas to check in diagnostics and if you do not know what you are doing if you ever get into it, dont try to change setting.
The service manual covers an extensive amount of information. There is a booklet that goes with it with the diagnostics setting and shows how and where to change them.
For this type of problem, it is better to call your Xerox service representative, pay the fee and let the service representative explain your options before you pay more money and time to repair the machine. Time is not on your side with a machine that has been out in the field for a number of years. Plastic cracks in places you never thought of, and rubber decomposes and turns to a goo substance, like a jell.
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
Xerox 3535 error code 102 372
have a xerox 3535 with one blinking light and error code 102 372 on start up any ideas ?
Oct 15, 2009 | Xerox DocuColor 3535 Copier
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox 5855C Copier
it need to replace the connector in the toner cartridge
Dec 11, 2008 | Xerox 5855C Copier
81 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
