Question about Ford 8n,9n,2n, Tractor Starter With Drive
Have an 8 N ford tractor with the starter drive stuck extened and wont retract.Help
  • 37 Answers
If hitting it with a hammer didnt help then unbolt it take it off and spray down in it with ether or stating fluid w-d-40 is to oily it wont dry clean should work fine
Posted on Sep 15, 2010
How to remove starter on 06 ford taurus
I usually use a starter removal tool... you want the correct answer, engine size and posting this is the automotive section will help
Aug 23, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford truck150 xlt triton 2007starter
Check that battery has full power Check terminals are clean and tight. If starter is old and done a lot of work check brushes for wear. If worn may need complete overhaul. Check that holding studs are tight.
Jul 18, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
8N tractor
check your push button starter make sure it is working,or my be the points may be stuck
Jun 16, 2013 | Ford 8N Tractor
The bendex in stuck to the flywheel on my 8n
I have the same problem as Derek. I pulled the casing off the starter and the armature along with the Bendix stayed stuck in the bell housing. I tried tried putting the tractor in gear and rocking it back and forth with hopes that the bendix would pul away from the flywheel. No luck. I think I'm going to have to pull the thing apart.
Mar 24, 2012 | Ford 8n,9n,2n, Tractor Starter With Drive
Diagrams_For ford 2N tractor starter
If you have not already found the info, I would suggest visiting the following website for some detailed help:
mytractorforum.com
No cost but will have to join to post questions. Likely all info can be had simply by searching the Ford "N" section. Good Luck!!
Oct 29, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
How to remove starter drive on ford 9N
You need to compress the front of the drive enough to drive out the roll pin,then the drive should slide right off.
May 06, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
Need to replace 9n tractor starter when you turn ignition key the starter just keeps going around.
I suggest that you pull the starter and make sure the bendix unit isn't stuck on the shaft which may be rusted or dirty and corroded first. If the starter spins then the starter itself is probably okay. Hope this helps you
Oct 16, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Having trouble with 1942 Ford 9N tractor.
You have a ground not grounding could be the switch itself and it may be the voltage reducer to the coil.
Aug 17, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
366 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
