Question about Onkyo TX-SV727 Receiver
Mi onkyo tx-sv727 no enciende la pantalla principal, prende en standby
simplemitch
  • 752 Answers
SOURCE: Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
Posted on Sep 15, 2007
SOURCE: Onkyo TX-8522 stuck on standby
This is Not a real Fix, However it stops the problem!
Do not plug any power cords into the Receiver.  I have found that using the "switched or unswitched" plugs in the back cause the trouble.
Posted on May 12, 2008
  • 142 Answers
SOURCE: standby button stuck
Hello. Check all of the buttons on your unit to make sure that they are not stuck...you can feel the click they make as you push it then they pop back out as your finger pulls off. Any stuck button will lock up your microprocessor and keep the unit from turning on. All other problems will require a consumer electronics technician to trouble-shoot the turn on circuit. If you know how to use a meter and know how to solder\unsolder and require further assistance you can contact me. Good luck.
barneyluc
Posted on Oct 19, 2008
  • 4234 Answers
SOURCE: receiver does not power on. standby not on either
The standby light should be on. If it is not, then check the main fuse. WIth the unit unplugged, remmove hte top cover and check the fuse by the line cord. If that is ok, then you will need to check the primary winding on the standby transformer. That transformer has a thermal fuse internally located and that sometimes gets blown due to a power surge. If you do not have the equipment to test this, get a detailed estimate from a local servicer. The standby transformer usually costs arounf $25 or so.
Dan
Posted on Apr 26, 2009
SOURCE: onkyo tx-sr500; power goes out; standby light blinks
Remove all Wires form speakers
Power on
Push Video1 + StandBy /On
appears Clear on display
Posted on Jan 26, 2010
Mi ranger prende i se apaga a fuerza le prende el foco de la pila y la auja de la carga esta abajo no se que es alguien save
Diana si se enciende la luz de la bateria lo mas comun es que necesites remplazar el alternador asumiendo que la correa este en buenas condiciones
Aug 07, 2015 | Cars & Trucks
Se apago mi tv led electrosonic y no prende
Fallo de la placa principal fuente de alimentaci?n del regulador. Compruebe y sustituya los componentes da?ados / s en su principal regulador de potencia [SMPS] Circuito secci?n. P?ngase en contacto con cualquier t?cnico de servicio. Si desea obtener algunos detalles; comprobar el sitio vinculado aqu?. Navegue por la web con paciencia. Tire hacia arriba de las entradas m?s antiguas.
Ser? mejor para reemplazar el tablero regulador de la fuente de alimentaci?n como base la tarjeta en lugar de hacer "cirug?a" a ella; que por lo general har? que la p?rdida de dinero y tiempo. A pesar de que usted puede hacer las cosas bien, que costar? alrededor de una cantidad igual al coste de una nueva junta directiva; incluyendo el costo de (partes + cargo por servicio de repuesto) M?s que decir, la mayor parte de las piezas de repuesto ser? dif?cil obtener de libre mercado de repuestos electr?nicos. Esto es cierto para la mayor?a de los tableros de alimentaci?n del televisor de pantalla plana de suministro; independientemente de su marca y tama?o de pantalla.
Jan 29, 2014 | Insignia IS 20" TV040919 TV
Como Reparo un Plasma Panasonic Viera TH-42PD60X no enciende ni el led de Standby
AMIGO YO TE VENDO LA TARJETA DE PODER PARA QUE NO SUFRAS MAS CON ESE APARATO , O TE COMPRO LA PANTALLA PARA EL MIO QUE ESTA QUEBRADA ,
Compro pantalla para PLASMA PANASONIC TH-42PD60X la mia esta rota, o vendo mi plasma para repuestos , tambien vendo una base para este plasma ya que tengo 2 unidades . gracias interesados escribirme a jaimolb@hotmail.com informes tel 0057 3207250204 colombia
Jan 21, 2012 | Cars & Trucks
Mi n-97 no enciende para nada y no se como solucionar mi problema
Hola estaba usando mi nokia n 97 y se apago y n prendio mas lo enchufo para cargar todo y prende la lucesita como que esta cargando pero la pantalla no hace nada
Sep 05, 2011 | Nokia N97 Cell Phone
Mi traductor no enciende la pantalla
estara bloquedo tu traductor lee el manual talvez tiene contraseña
Jul 24, 2009 | Franklin Merriam Webster BES-1850...
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Mar 24, 2009 | Computers & Internet
Mi pmp carga y enciende su luz pero no quiere encender el aparato
YO TENIA UN PMP ME PASO LO MISMO. Y TEMO DECIRLES QUE MURIO, TUVE QUE CAMBIARLO, LO QUE ME DIJERON FUE QUE SE DAñO LA MEMORIA Y LA BATERIA, ASI QUE PAILA. TAL VEZ EL TUYO NO SUFRA LO MISMO
Dec 06, 2008 | iRiver PMP-140 Digital Media Player
Pasword pass
Lo que necesitas hacer es, cuando la unidad te pida el codigo,con el control remoto apuntalo asia la pantalla y forma la palabra KCAR con los numeros 55222277 o aveces es 552222777 dependiendo del control remoto que estes usando.
No vas a ver ningun cambio,ni ninguna letra en la pantalla mientras estes poniendo los numeros con el control hasta que pongas el ultimo numero requerido,la unidad se pondra en STANDBY y listo.
Si cometes algun erreor presiona el boton de reset en la unidad y trata de nuevo del pricipio.
hasme saber si trabajo
GRACIAS
Jun 07, 2008 | Kenwood Excelon KVT815DVD Car DVD Player
73 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
