Question about Garden
This is a lawnboy mower about twenty years old and has run fine intil about a week ago. Now...after starting...It will surge up and down at full speed...then start to bog down unless throttle is placed in the "choke" position. Then will run a little bit longer...then die. Because it will run in the "choke" position, does this indicate it is not getting enough fuel (running too lean)? I placed 2 oz of sea foam in with the fuel...but doesn't seem to help (unless I haven't waited long enough to have it work into the fuel line). Any advice would be appreciated.
  • 37 Answers
Drain all gas out of the tank and carb the new gas with 10% ethenal is ruining old gas engines after everything sits for a day install a plastic shut off valve in gas line. put high test gas with the seafoam then turn gas valve off after every use it will run good. then call your congressman and complain otherwise we will all be replacing any engine older than 4 years old
Posted on Sep 15, 2010
2009 190cc Briggs starts but won't run
Ensure the oil is full. It has an oil low sensor. 30w oil.
Jun 13, 2013 | Toro Garden
My Kohler 25 hp engine surging up and down at full trotal and stops runing if trotaled any lower
sounds like you have a govenor coming apart inside the motor.
Oct 23, 2012 | Garden
Engin runs fine for about twenty minutes then quits. oil level is full
try and run it with a loose gas cap the vent could be clogged then check for spark when the engine dies or even better get a inline spark tester then you can see it when its dieing
Jul 12, 2012 | Garden
Lawn Boy 10641
see if the oil smells like gas the carb maybe sticking and gas gets into the oil washing the oil out this will make hard starting and smoke if so the needle valve is not sealing if you caught in time without major engine damage a sign is the oil being over full and smelling like gas
Apr 03, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Lawnboy 6.5 b and s motor was backfiring loudly when trying to start now when engine runs and heats up it cuts out and will not restart any ideas??? ran fine for a year and a half.
you need a valve job and have a unseated intake valve might have to get new motor if cant seat valve have to take to shop if cost 3rd by new mower
May 15, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Jul 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Toro 6.5 hp 9 year old mower. Starts Ok; surges
Sounds like your carburetor needs to be cleaned out. The surging is usually a sign of running to lean (not getting enough gas) because of possible water, rust, gum, varnish or trash in your carb. Hope that helps.....
May 17, 2009 | Toro Lawn Mower With Toro Power Tools
Lawnboy 10685 mower surging problems
I hope that the shop didn't rebuild the whole mower engine for you if you took it in for a surge. If you mean they rebuilt the carburetor, that's what it needed. I'd call them, tell them it's doing the same thing as it was before (starving for gas, causing the governor to "hunt"). The carburetor is dirty inside. You have a blocked/partially blocked jet. You can either take the carb off yourself and try to clean it, or take it back to them and let them try again.
Here is a thought. First, before you take it back to the shop, take the small bolt on the bottom of the carb. This holds on the bowl. You do not want to take this off if the machine is full of gas, cause it will leak all over your mower/floor. Tilt the mower backwards or try to drain the gas out. When you get this little brass bolt/nut out, and get the gas cleaned up that leaked out, if you look real hard you will see a very tiny little hole in the shaft of this little bolt. Some even had 3 of them. It may appear to be just a blemish in the finish, but it has to be clean to allow proper operation. Spray with carb cleaner, and take a small wire, such as a single strand of a speaker wire or something similar. Clean that hole/holes out. Clean out the inside of the bolt shaft as well, as debris will settle in there. Put the bolt back in and tighten the bowl up. Make sure the bowl is straight and the gasket is back on the little brass bolt. Tighten snuggly, but not forced.
Try that. If it works, and the mower runs better, put some carb cleaner in the gas and run a bit.
May 17, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
