Question about Bosch PRO1072SM 10 Inch 72T Miter Saw Blade
I need a replace motor cover for a Ryobi TS252 Mitre saw
3 Suggested Answers
  • 302 Answers
SOURCE: ryobi mitre saw wont open tried pushing in a steel
there should be a lock pin behind the fence that engages the pivoting head that needs to dis-engage before the saw will open up for you. This keeps the head locked down when you are hauling it around
Posted on Aug 26, 2009
  • 6 Answers
SOURCE: Motor replacement for Bosch Mitre saw
Most often the entire motor doesn't go bad. It would be a componen't like armature, field, brushes, Switch. I very seldomly see a whole motor go bad. look for a single problem. The saw is not junk it is very repairable with some testing of parts.
Posted on Jul 25, 2010
How to lower toptable of a ryobi table mitre saw tms-305
http://ryobi.co.za/product/table-and-mitre-saw-combination-1800w-tms-305/
this saw has a 2 inch capacity. if you have say a 3 inch piece you use 2 passes of 1-1/2 each
regards
sir dana
Apr 25, 2017 | Ryobi Saws
I have a new 7/1-4 ryobi battery operated mitre saw all my batteries are new and run all my tools perfect, but on the mitre saw has only slight power but cant cut anything
make sure you are getting good connection to the battery for that tool. Is the blade reasonably sharp? YOu don't say what voltage but those saws aren't that torquey anyway. Sounds like a problem with that particular tool.
Jan 08, 2015 | Ryobi Saws
Ryobi 10 in Mitre saw with laser, switch / motor wiring diagram?
capacitors are known as capacitors or condensers. Both do the same job of storing electrical energy and then releasing it when the current flows back . They are used to either start an electric motor or stop arcing on the brushes by absorbing the current flow as it stops over each commuter bar of the armature
Dec 02, 2012 | Ryobi 10 In Miter Saw With Laser
I have a ryobi 10" mitre saw and i took the guard
I don't know but if you have figured it out let me know. I have same prroblem.
Apr 19, 2011 | Ryobi 10 In Miter Saw With Laser
Compound Mitre Saw Motor turning, spindle isnt.
I have went to 3 different sites and cannot find the model number listed on them, I did look at a Ryobi saw and they indicate it is an assembly. but before I did that I would try and removing the gear from the spindle. It is possible that when it spun it put a burr in the parts and you would have to use a little extra effort to remove them I would suggest going to a repair shop and having them press them apart and see what you canfind that way. Sorry I couldn't find more for you
Jul 30, 2009 | Ryobi Saws
How to change blades on an old Ryobi 380mm cut off mitre saw?
most of these saws have a push/lock tab on back side of motor housing that pins the shaft for blade change. if you cant find, use a 4/4 wood block to wedge old blade so you can loosen bolt.. hope this helps....chris
Jun 18, 2009 | Saws
Bosch PRO1072SM 10 Inch 72T Miter Saw Blade Logo
46 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
