Question about Olevia LT42HVi 42 in. LCD Television
Copy protection the dvi/hdmi output is blocked press exit to cancel
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
I am getting 'HDCP unauthorized content disabled '
You are playing content over an HDMI cable that contains a copy blocking system. This is the reason that manufactures pushed HDMI systems instead of DVI. Digital content protection was the whole purpose.
Jan 04, 2016 | Televison & Video
HDMI slot is absent in this tv. How can I adapt it to handle HDMI?
Yes, the Panasonic PT-50LC13 has a DVI port. There are DVI to HDMI adapters to handle the conversion. You will need an HDMI F to DVI-D M adapter (like this: http://www.amazon.com/Importer520-Plated-Female-DVI-D-Adaptor/dp/B0035B4LJM/ref=pd_sim_e_1 ). Alternatively, get an HDMI to DVI-D video cable (both male ends) of the appropriate length. You will need a separate cable for the audio. Make sure that your source has a separate analog audio output available and plug that into the DVI audio input (RCA R/L). If your source has a only digital audio output and the HDMI port, you could use a digital-to-analog audio converter to provide this audio. For example, this would work: http://www.gefen.com/kvm/gtv-digaud-2-aaud.jsp?prod_id=5279 .
Please note this will not handle the signal from most computers. They send a different signal then the TV can handle. Copy protected content (DRM) may not be correctly translated by the TV. Most Blu-ray movies require HDCP compliant TVs and monitors.
I hope this helps.
May 27, 2013 | Panasonic PT-50LC13 50" Rear Projection...
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
How do i connect my z5610 to my hd tv there is no hdmi or vga output on the pc
> no HDMI or VGA output
Every PC has either one DVI or one VGA output.
Does your z5610 have a DVI input? If so, connect the DVI-output to the DVI-input.
Or, add-in another video-card that does have HDMI output, and connect HDMI-output to HDMI-input.
Mar 06, 2011 | Computers & Internet
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Connection problem with HDMI cables on Denon AVR-589
I want to clairify you install, you sat you have I an HDMI cable running from the Time Warner Cable box to the AVR-589, going in to the TV/CBL input. From the Denon AVR-589, I have an HDMI cable running from the output to my Toshiba RV525U television.
Check the connection at the TV, if as you indicated above you have an HDMI cable from the HDMI out from the Denon to an HDMI output on the TV, if this is the case you need to have that HDMI cable plugged into an input on the TV not an output
Feb 27, 2009 | Denon AVR588 Receiver
Crt 4:3 to a 16:9
If your CRT Monitor has a DVI input you can certainly get HDMI to DVI adaptors (Maplin etc) but if the monitor is Analogue as I suspect you will need to find a Digital to Analogue converter. The problem here is that HDMI is copy protected and any analogue outputs must be disabled when HDMI is selected to prevent coping. I am assuming this also applies to your PS3 !!!!
I do agree with you about picture quality. I have a Samsung 21" CRT monitor which has a pixel size of 0.2 and is far superior to even the best LCD.
Apr 24, 2008 | Televison & Video
Olevia LT42HVi 42 in. LCD Television Logo
142 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
