Question about Fisher and Paykel GWL11 Top Load Washer
My washer has lost all power. I read that there may be a main fuse some where. Is this true?
  • 72 Answers
There are fuses, first i would check the safety interlock switch. there are two screws on the top and the back, that hold the control panel in place. the safety switch is on the bottom near the right hand corner, push the switch button in and the machine should work. remember you are playing with high voltages in a wet enviornment, therefore you doing this at your own risk. if unsure, get a technican in.
Posted on Sep 25, 2010
My technika tv has lost all power
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 12, 2016 | Televison & Video
Tip
LCD TV TROUBLE SHOOTING
1.Do not power on .
1 .1 Please check AC cable if connect to AC plug. Is true the connector don't connect to AC plug. Please connect it.
2.2 Please check AC cable if connect to AC power. Is true the AC cable don't connect to AC power. Please connect it.
3.3 Please check power board of fuse if broken. If the F1 fuse is broken, Please pull out the AC cable from AC power. Please check AC L power and AC N ground by multimeter, The read number is infinite, the fuse is broke. Then look up power board if not burn out place. Is true it. Please change power board or be changed power board.
2. The power on switch of green extinguish.
2.1 The power of led(indicator light) is red light, To touch power on key when indicator light wink. Is true that the power DC output have somewhere short circuit. Check connector J39,J31 .If not connector direction is wrong. Or the mainboard somewhere of power short circuit.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
on Feb 14, 2015 | iLO Televison & Video
Steven its a 99 s 10 no power at the fuse ?
im moved you.
to S10
no power mean the voltmeter is not 12v>???????
the fuse has 2 ends, no power to me means both ends, right.>?
what fuse box, cab or bay?
that means the power ;means the fuse in cab is dead because the
MAIN fuse in the BAY is blown.
just like you home there are main fuses then sub branch fuses.
then the battery, its dead, all is dead.
1 step at time use the voltmeter and walk backwards to battery
and find the OPEN circuit. whomever it is. (chips fall where the may)
as will TRUE cause.
Jun 15, 2014 | Chevrolet 1996 Chevrolet Blazer S10/jimmy...
Lost Power and lost temp reading on front door, currently reading 88 and flashing.
try to reset your unit or unplug 3minutes then restart unit. or check if it has a busted fuses replace it. if problem persist replace main pcb baord
Feb 06, 2011 | Samsung RF267AB (25.5 cu. ft.)...
My 1999 nissan altima is just shutting off, all power is being lost and i traced it down to the main 100amp fuse, i replaced the fuse and it is still hapening so i am assuming the problem is in the main...
Check the fuses near the battery leads, the positive battery lead. There are fuses attached to the battery lead if I remember correctly mate..I think that will fix your issue.. cheers
Jan 10, 2018 | 1999 Nissan Altima
All of a sudden, there is no light on the button. I have check the electric outlet, it is OK. I pushed every button, but it doesn't work. Is there a fuse on my washer? Or anyother problem?
There should be a dedicated circuit breaker in your main panel.
Check that first.
Then verify power at the outlet with a multimeter.
If there is power at the outlet - unfortunately, there is internal damage to the main board (typically from a power surge) and further testing is required.
Thanks!
Jul 27, 2010 | Frigidaire ATF6000ES Front Load Washer
LG WASHER WON'T Power on
Hello. If the lid switch is defective, your washer may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 24, 2010 | LG WM1814CW Front Load Washer
I have no power to my machine. the plug is in and the the fuse box is fine in the house and still the machine wont turn on. i started a load of laundry and it lost power befor it finished.
If the lid switch is defective, your washer may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't work until you replace the fuse.
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
99 1/2 jetta
Yes - relay 109 is your main power fuse and they're famous for going bad. Read this thread - it's from a TDI website - but it's exactly the same. The TDI guys really know their stuff.
Jul 12, 2009 | 1999 Volkswagen Jetta
Fisher and Paykel GWL11 Top Load Washer Logo
48 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
