Question about Samsung Behold II SGH-t939 Smartphone
Phone freezes when i open the the camera app.
  • 28 Answers
TRY DOING A MASTER RESET, IT MIGHT WORK.
Hard Reset
  • Shut down the device
  • Press and hold the End key, tap Power Off, and then tap OK
  • Remove SIM card
  • Remove the battery cover, the battery, and then remove the SIM card. Replace the battery and battery cover.
  • Three-key combination
  • Press and hold the Volume Down key, Send Key, and then End Key in succession. Make sure that all three are being pressed simultaneously and that the End Key is pressed last
  • When the graphic is displayed, press the Menu key to begin factory reset
  • Posted on Sep 15, 2010
    Try open inbox freezes
    Go into settings, then manage apps, go in and clear your caches on each downloaded app 1st. Then go into your playstore and find a cache cleaner/memory boost. This should help remind you to keep them cleared up and it will stop freezing and run faster.
    Jan 30, 2014 | Nokia Cell Phones
    Phone keeps freezing
    > Check the number of applications that are running in the back ground close some and check if it still freezes
    > Try to identify from when the phone started freezing - if there was an app you downloaded prior to that uninstall that app and check if still freezes
    > you can also install an anti virus and run a scan to check if your phone is infected
    Oct 23, 2013 | Vodafone Cell Phones
    Android homescreen freeze
    if you're using any kind of task killer app or autokiller app then disable/remove them . task killer apps usually kill widget processes and services which results in the freezing of your widgets .
    hope this helps .
    peace :)
    Jul 13, 2013 | Samsung GT-S7562L Galaxy S Duos Android...
    Htc amaze camera freezes
    Reset Phone Not a Solution _ Tested by Myself _ Reset Not Worked(4me) _then i tried to Wipe it out my htc amaze rom and installed it again _ but still its not working _ then i thought may be there is some hardware parts are moved or loosed from it place_ checked _ around 3 Times _and replaced all the parts Carefully but still not Fixed .. Guys u can try the last step but may b no result come to U_ So may b this case need a professional Help From the htc Department or any other Dev. Dept.
    Jul 12, 2012 | HTC Amaze 4G Smartphone T-Mobile
    How do i keep my android phone from freezing
    Its either a hardware problem or an app causing it, to check what it is you will have to try downloading advanced task killer to the phone, install it, open it and everything by default will be checked or already set to stopp all services, at the top of the app it should say " KILL selected apps" touch that let it stop all services and see if the phones freezes after that, but just to mention the ophone may slowly respond if it needs any servies for a few seconds while it only restarts services that are crutial to some of the other things running, but still , after killing all services go back to the home screen and then try and play music or access the internet on the phone and see if it then freezes, if it no longer freezes then its an app, if it continues to freeze then its a hardware issue or corrupted android software, at the point you can only hard re-set the phone (going back to defualt) this will wipe everything off the phone except memory card and try that otherwise its a hardware problem. phone then needs replacing.
    Oct 09, 2011 | Samsung Infuse 4G Smartphone
    IPhone camera shutter won't open! - 3Gs
    there is a hardware issue. Apple should give you a replacement. If you're out warranty, you can try to open it and camera module. If that fails you need a new logic board. You can get the part on Ebay or at iPhone Repair and there is a free guide that shows you how to open a kindle and install parts at iPad Repair Guide.
    Sep 29, 2009 | Apple iPhone Smartphone
    IPhone Camera shutter doesn't open on Camera app
    This is an internal problem with your camera phone. Send back to carrier or Apple if under warranty or find authorized repair in phone book.
    Sep 03, 2009 | Apple iPhone Smartphone
    Camera on Rumor 2 Not Working
    try other camera apps or try reseting the camera app if both does not work reinstall your phone software
    Dec 05, 2017 | LG RUMOR Cellular Phone
    Phone freezed
    i just got a new mobile buh u had to use the sim card given buh i wanted to use my own and i entered my pin but then it came up NETWORK LOCK so then i kept on tryn and now my mobile is freezed how do u get the password and the lock for the network lock ?? :(
    Jul 20, 2009 | Samsung E590 Unlocked GSM Phone
    Phone freezes whenever I press "End" key or the "Clear" button
    Hey,
    Thanks for nothing people. I figured it out myself. It turns out I had a miniSD card I had been using with my laptop in the phone and it was formatted in a different format that the phone didn't recognize (I use Linux on my laptop, and Linux uses different file formats then Windows). The different format must have caused the phone to freeze, because after I took the miniSD card out, the phone went back to working properly (unless smacking it on the table whenever it would freeze helped. lol jk jk). I hope this helps someone else who has trouble with a freezing eNV.
    Adios Beeches,
    -OP13
    Jun 18, 2009 | LG enV VX9900 Cellular Phone
    Samsung Behold II SGH-t939 Smartphone Logo
    229 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
