Heating & Cooling Logo
Posted on Sep 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need wiring diagram for a york condensing unit model # e1ra036s06d
Dennis Boxerman
Level 3:
  • Master 1,306 Answers
  • Posted on Sep 15, 2010
Dennis Boxerman
Master
Level 3:
Answers
1306
Questions
Helped
646286
Points
2787
Http://www.yorkupg.com/IntDocs/pdffiles/035-15857-402-b-0402.pdf
go to this site. in the manual, there is a wiring diagram that may answer you question for a diagram. hope this helps.
Need wiring diagram for Bryant packaged unit model 564ANX030000AAAD
https://www.manualslib.com/manual/22260/Bryant-564a.html#manual
LOOKING FOR THE WIRING DIAGRAM FOR YORK CONDENSOR H2CB060S46C. THANKS
Call York but the units only got 2 sides of power and a compressor and fan motor! L1 and L2 go to common and run on compressor and run cap to run and start on compressor condenser fan will be powered off the contactor, there really isnt much to be worried about with any diagram? what specifically are you trying to figure out?
Thermostat wiring from York air handeler to York condenser
For a competent expert to be able to answer your problem, you will need to givea specific make and model of your unit.
Also include as much as possible about what you have already tried to do toresolve the problem along with exactly what is not working or what the unit isnot doing that it is supposed to do.
This will help us experts to be able to give you the correct advise the firsttime, without having to guess so much as to what is actually happening.
Thank you!
heatman101
1helpful
Need wiring diagram for york n4ahd20a06a air handler
any york distributor should be able to accomidate u get ur model and serial number and call ur york dealer they should be able to order it and they r usually prett cheap
1helpful
2answers
York Heat Pump outdoor cutoff thermostat wiring.
You should call a professional in on this one you can damage alot of expensive parts trying to do this on your own without the proper tools and knowledge of the control logic
4answers
INSTALLATION MANUAL FOR PV9C YORK FURNACE
I just replaced a thermostat on a york furnace model gy9s100c16up11h. During the process i connected the red and white wire and the unit came on after making the connections it will not come on even if I jump the red and white wires without the thermostat. Thanks Dan
1helpful
2answers
York
I have an old York outside compressor/coil/fan unit, CDHF36-6A, that I need to replace as it is no longer repairable. What is the capacity of this unit and what Carrier unit would be a good replacement?
Adair
Top Heating & Cooling Experts
Paul Carew
john h
