ERROR 5L WASHER MACHINE CALIPSO. THANKS - Washing Machines
  • 15,935 Answers
The error is SL.
SL = Suds Lock
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer/main controller/timer failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
We got error code SL or it may have been 5L...not sure but it was after the Ld code..what does that mean?
this is a long or slow drain issue you will need to check the drain pump for obstructions.
Feb 02, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Model # 110.22064101 Kenmore calypso elite washer makes a whirring sound when washing and the washer tub doesn't always stop correctly when the cycle is complete. It will move around instead of being...
The motor coupling is about to completly go out on you and then it will not spin at all. This is common on these machines. the repair should be under $100.00. The motor brake may also be dragging.
Nov 10, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Calipso it fills but LD comes on and nothing
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer gets to 20 min left in rinse cycle recuriculation pump comes on and off anything from 5 seconds to 2 min control countdown stays at 20 min for over 20 min? whirlpool calipso
usually problem with digital washing machine is on the program module, exactly in the water level sensor, please check the hose that connected to water level sensor, make sure no dirt blocking or clogging the hose. also you can clean the tube under the pulsator, usually there is many dirt blocking the hoseline.
Jul 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calipso model clothes washer shows a LD and doesnt run
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Jul 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
SL or 5L error codes, Fixed?
Sorry, I haven't. In fact, I started to use my older washing machine, because I got someone to fix this one and it still wouldn't work. He told me that the newer models are not built to last, and that they are purposely built to break down and need constant fixing. Good luck.
Jul 12, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calipso wash motion
your inlet filter is most likely plugged.
take of your hoses from the machine and clear the filters in the machine inlet ports.
If this does not help your inlet valves are broken.
But most likely the filters is the good bet
Kenmore Elite Calypso Washer
I'm in the process of tearing apart my Calypso, Ugh. I found the diagnostic chart inside the machine. 5L is actually 'SL' which means suds lock, and can be an indicator of a failed pump, an extra heavy load, excessive detergent, or excessive suds. Corrective action is to press Stop/Cancel to clear the display.
Mar 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
5L error code
I will pull the book and get back to you today
Jan 27, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
