Question about Dishwashers
Run on the normal cycle the dishes come out smelling "fishy". I refill the jet dry every 2 weeks--it always seems empty and I know that's not normal for dishwasher use. Even the empty dishwasher has a "smell". Our water is excellent for drinking--it is not well water and has no odor. Please advise before I have to buy a new dishwasher. Our dishwasher is a Quiet Partner II.
  • 901 Answers
Check the main drain, wher you are connecting the drain hose.
Posted on Sep 15, 2010
Dishwasher smells
johnnette acree, here are a couple possibilities
1. Look in the bottom of the dishwasher there is a catch basin or cylinder look for large food item that maybe stuck. clean it out.2. Be sure the drain hose is connected with a loop in it that goes up to the top of the cabinet and then back down.3. Run the dish washer empty with soap and heat dry or use sanitize cycle. after cycle completes leave dishwasher open overnight. The smell should be gone in the morning.
Hope this helps
Joe ConnollySealstonetops@gmail.com
Nov 16, 2011 | Frigidaire Dishwashers
Fusty fishy smell coming from saniflo unit
Dean:
You need to check and see if the unit cycles immediately after you flush. After that, try tapping on the outside of the unit with you hand (thump it) to see if the unit will cycle again. If it does, it is not emptying completely. The issue is then with the air cycle valve.
If it seems to be cycling ok, go to Home Depot or Lowes and look for the Zep (Brand) enzyme drain cleaner. Put the enzyme cleaner down the sink (if one is connected) and let it sit for 24 hours. This will help clean out any sludge in the unit. You might try the enzyme treatment once a week for a month and see if that helps.
Normally, I have found the smell comes from the units not cycling properly and completly emptying the units to the proper level. They stay overfull and generate the smell.
If its the air cycle valve, let me know and I will tell you how to address that issue.
Martin Rizzo
mrizzo@liquecolor.com
Nov 12, 2011 | Saniflo & Saniplus& Macerator Pump
The dishwasher works fine but the jet dry doesn't seem to release to clear dishes. I have cleaned it out and put new liquid in. It always seems to be a the same level and never needs refill. Glasses are...
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Apr 02, 2011 | Maytag Dishwashers
Fishy smell after the dishwasher runs
Do this. Pour two cups of white vinegar into the empty dishwasher and then run your longest and hottest cycle. This will clean and sanitize your machine. Do this as often as needed. J.
Jul 02, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Not drying dishes
Without knowing the make and model of your dishwasher, the most probable causes of no drying is:
1.) RinseAid being empty or not dispensing (as in you never seem to have to refill the dispenser.)
2.) The Heating element has failed. But if it has failed, you would also have foggy, film on your glassware.
3.) The timer is failing to turn on the heating element during the (at least) the heating element during drying cycle.
Good Luck!
Apr 06, 2009 | Dishwashers
Dishes not dry at end of cycle
check to see if your jet dry dispenser is empty and on some of them you can turn them up higher its important to use a rinse agent back when everyone was trying to cut down on energy use the only way to to it was to cut back on drying time so they came up with jet dry which creates a sheeting action and causes most of the water to run off before the drying cycle
Jul 14, 2008 | Miele 24 in. G892SCU Plus Built-in...
Dishwasher smells like pond scum
I have the SAME problem with our dishwasher. It's disgusting. Between the fishy glasses and the garlicky ice cubes (NO, we don't have garlic in our refrigerator or freezer -- purchased ice doesn't smell), I'm embarrassed to pour our guests a glass of ice water!
Jun 05, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Food Deposits left on dishes
I had an old machine with a similiar problem & I found that food had somehow entered into the arm that spins & sprays out water. The food blocked somewhat the holes which of course means less cleaning.
Mar 05, 2008 | Maytag 24 in. MDB5601AWS Stainless Steel...
Bosch diswasher
If it is new- then the fishy smell is almost certainly the motor and circuit boards 'cooking' in- most motorized electrical devices have an initial pong. However if it persists after say 10/15 cycles begin to suspect an incipient fault.
May 14, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwashers Logo
229 people viewed this question
Top Dishwashers Experts
