Question about HP Office Equipment & Supplies
Printer purchased 15/5/08 on trying to set up red light continues to flash so unable to print and proceed the screen only shows the language selected and fails to move on
    Genius:
  • 2,785 Answers
Your printer may be malfunctioning you better tell the vendor to check as it is on warranty
Posted on May 16, 2008
  • 37 Answers
Usually printers like to flash red under the following conditions:
1. Paper jam. So be absolutely sure there is no paper stuck in there, or that a piece of paper is not partially fed too far for the printer to pick it up as a new piece.
2. Out of paper, speaks for itself.
3. Wrong paper tray selected. i.e. you install the printer using default settings, but somehow, the printer is expecting to 'see' paper via an alternate input / tray. Check the printer settings to see if the paper tray matches the tray you are feeding paper too.
This one has caught me out many times.
Hope that helps.
Tip
Print Head Cleaning Cycle
Please confirm that the head cleanings were done using the most effective method listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
Use the Printer Driver Utility to clean the print head. Alternatively, try this SSC Service Utility.
Also try changing the affected ink cartridge.
All else fails, your printer will require service.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
on Jun 15, 2008 | Epson Stylus Photo 1280 InkJet Printer
Have Ultra Hi-Definition RX595 Photo all-in-one print,copy,scan,photo. After setting everthing up and when I print from word or anyting the print comes out in color. I thought I could have color or b/w...
1) Make sure the printer is turned on but not printing. Ensure there are no error lights or messages appearing in the LCD.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
Aug 21, 2008 | Epson Office Equipment & Supplies
WHEN PRINTING PHOTOS LINES APPEAR
Hi, It is unfortunate that you are having this difficulty with your printer. One of the best solution that we can give to you is run a series of head cleaning. Please try the following steps below to clean the print head in most effective way:
1) Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
3) Click on START.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink, your printer will require service.
Tirzo
Jun 13, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Printing Problems with Photos
you can try this one just to isolate if it is an issue with the software or with the hardware itself
it is just for windows users only
3) Click on START.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Mar 07, 2008 | Epson Stylus Photo R220 InkJet Printer
Problem printing
3) Click on START.
Dec 29, 2007 | Epson STYLUS CX3900 All-In-One InkJet...
Color printing problem for Epson CX4200
try this :
3) Click on START.
Dec 29, 2007 | Epson Stylus CX4200 All-In-One InkJet...
Dark red prints with lines throught the picture
3. Click on START.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
Printer doesn´t print using the mangenta ink cartridge
try this :
3. Click on START.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
Dec 20, 2007 | Epson Stylus C63 InkJet Printer
Printing in blue only
try this:
3) Click on START.
Dec 12, 2007 | Epson Stylus CX6000 All-In-One InkJet...
75 people viewed this question
Seeker5211
Seeker5211
