Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
The freezer is running all the time. I checked the coil and it is not frozen. I had both setting on 9 for about 1 month so I don't know is it could be the freon or what it is.
  • Hotpoint Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 18, 2010
Unplugged fridge 9 months and now it doesnt cool at all
it's 20 years old,replace it,don't waste a penny into that machine,most likely you have a problem in the sealed system compressor and freon so don't waste any of your time or money.good luck,if you say the compressor and fans are running and it's not getting cold one of the lines could have rotted out and the freon gas leaked out,you can remove the back inside wall of the freezer and look at the evaporator coil,if it's running fine you should see an even frost pattern covering the coil,if you only see frost where the lines connect to the coil you have a freon leak but i wouldn't even waste my time doing that on this machine just repace it.
Jan 01, 2014 | Refrigerators
Freezer is running constantly. ice crystals formed on outside of packaged foods. food is still frozen.
the door was left open,if you find frozen water droplets on the food packages or ice crystals it forms from the warm air coming in,make sure all the packages are pushed in and not hitting the door and you can tilt the fridge back a little so the door will close with a slight push.also check the ice shout door and make sure no air is leaking through it,you'll know you'll see all ice around it.you can check the condenser coil and condenser fan to see if it needs to be vacuumed,the machine will run longer if the coil is clogged with dust or if the fan isn't blowing,the coil should be cleaned every 6 to 12 months.hope this helps but it sounds like the freezer door was left open.
Sep 06, 2011 | Frigidaire FRS23KF7AB Side by Side...
Coil freezing on a ge model gsh22kgpbcc
A frozen coil can be cause by several things.
Defrost heater bad
Timer bad
Thermostat stuck close (run all the time untill defrost)
Bi-metal defrost thermostat bad
Freezer fan bad
Freezer drain plugger.
if you want to know how to check these things we have to chat thanks
Mar 28, 2010 | Refrigerators
The unit over the course of 3 wks or so has stopped keeping things cold and frozen. Now both sides are turned up to 9 The freezer has a big snowy area in it. I dont know if trying to defrost it will...
try taking the back cover off of the freezer inside it u should have a fan see if its running if not check to see if u have got power to it if u do then just replace the motor and see if this fixes the problem if the lil coil under that fan is frozen and the fan is running then u should have a lil heat element black running through the coil see id this has power to it iif the coil is frozen and if not check continuity thru the element just take the wires off of it and see if u have continuity thru it if u do then the element is fine if u dont it needs replacing but if all this is working then ur defrost timer may be bad ull have to get the wiring diagram out usually hanging on the back of the fridge and see where the defrost timer is and see if it is working or some just have a lil sensor on the freon lines right on top of the coil to let it know when it needs to defrost that may not be working stick it on some ice and see if the element starts warming up hope this helps
Mar 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
FRIDGE NOT COLD FREEZER WORKS FINE
Make sure the freezer fan motor is running. Remove the rear panel in the freezer and check for frozen coils. If coils are frozen replace the defrost heater and thermostat.
Check the air vents to the fresh food section,are they frozen closed?
Jul 17, 2009 | Hotpoint HTS16HBMWW / HTS16HBMAA Top...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Frigidaire Chest Freezer Model LffC1466DW4. Inside coils are frozen and copper pipes underneath are frozen. I have let set unplugged for 2 days and tried again. Ice forms within a few hours. How do you...
you dont want to add any more freon to it to start with
it either has to much in it or the thermostat is not turning it off and making it run to long, you need to see what temperature you are getting in the freezer and what suction pressure the unit is running on to determine if it is over charged
Apr 29, 2009 | Frigidaire Freezers
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 | Freezers
Freezer coils and water in drain tube frozen
check to see if the fan running first, if yes than you may be losing freon. if not , try a new fan motor
Jul 29, 2008 | GE GTH18KBM Top Freezer Refrigerator
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
