Question about Singer Confidence 7469 Mechanical Sewing Machine
My feed dogs will not raise. The button in the back of the machine is in the raised position but the feed dogs stayed in the lower position.
SOURCE: feed dog
don't know how i did it but it is working now. thanks anyway.
Posted on Apr 02, 2008
mallow1
  • 35 Answers
SOURCE: raising feed dogs
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link to them:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Posted on Aug 16, 2008
  • 2976 Answers
SOURCE: Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
Posted on Jan 03, 2009
SewTechWayne
  • 186 Answers
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Posted on Feb 08, 2009
  • 43 Answers
SOURCE: How do I raise and lower the feed dog on my singer
On your Singer, you don't actually raise / lower the feed dog. Instead you attach a "darning plate" (which should have come with the machine) which covers the feed dogs so they do not come in contact with the fabric. See a page from the owner's manual using this link within my web site: http://www.sewvac1.com/Singer3080_Feed_Drop.pdf
Posted on May 06, 2009
Feed dogs will not raise up to feed the material. I checked and the position on the back is in raised position
if the feed dogs are in the raised position then the feed dogs need to be checked to see if they need a adjustment or need to be replaced
Apr 07, 2016 | Sewing Machines
Feed dog button is stuck in the in position won't come out to raise feed dogs?
"FEED DOG BUTTON" ISN'T QUITE CLEAR. HOWEVER, THE FEED DOG IS CONTROLLED BY THE STITCH LENGTH. IF THE STITCH LENGTH IS SET TO ZERO THE FEED DOG WILL STAY BELOW THE PLATE AND THE MATERIAL WON'T MOVE.
Jan 31, 2016 | Sewing Machines
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
Janome/New HomeHF 2022 How do I raise and lower feed dogs
With the straight stitch set to zero the feed dogs should be down. To use a different number will make the feed dogs rise above the plate.
Oct 23, 2014 | Sewing Machines
I have a brother ps-53 and after fixing an issue with the bobbin thread not raising I am now having an issue with the feed dog. When turning the balance wheel forward (or by using the pedal as if to sew)...
Sounds almost as if the feed dogs are canted or angled instead of being level. That's an adjustment you would need to get into the lower mechanics for. Other than that I can only wish you luck.
Sep 06, 2012 | Sewing Machines
My fabric wasn't moving so I lowered the feed dogs and now I cannot raise them. The button in the back of the machine moves both ways but the feed dogs are not moving. They are staying in the down...
Hello
Turn off the power. Remove the accessory compartment located in front of the machine, if applicable.
Open the hook cover that shields the bobbin area. Please note that you do not need to remove the bobbin case.
Locate the drop feed lever near the bobbin case. Some machines have the lever towards the back of the free arm. Press down on the lever and then move it to the next notch or position. The raised metal feed dogs should be visible through the openings on the needle plate. You may need to rotate the big balance wheel one rotation to engage the mechanism on some machine models. The metal teeth will then spring up.
Close the hook cover. Insert the accessory compartment, if applicable.
Turn on the power. Try test stitching a piece of fabric. The raised feed dogs should help guide the fabric under the presser foot.
Jul 12, 2011 | Janome 4623 Mechanical Sewing Machine
Raise feed dog
I have a different model Viking with a feed dog button to the left of the power button. When it's pressed down, the feed dog stays in the "down" position. Press it again to bring the feed dog up.
May 19, 2010 | Husqvarna Viking 1
good luck!
Feb 08, 2009 | Janome Memory Craft 4800QD
Feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Mar 18, 2008 | Sewing Machines
If you look at the back of the machine you should see the button that will let you lower the feed dog. It looks like you slide the button one way to lower and then the other way to raise the feed dog.
To make it a bit easier just go to the following web site and move down to the pictures as there is one showing the back of the machine. The button would be on your right:
http://www.ebay.com/itm/JANOME-MEMORY-CRAFT-5700-SEWING-EMBROIDERY-MACHINE-QUILTING-TOO-ADDED-EXTRAS-/301088834718
Dec 10, 2007 | Janome Memory Craft 5700
Singer Confidence 7469 Mechanical Sewing Machine Logo
133 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
