Question about Frigidaire GLER341A Electric Dryer
Dryer is not getting as hot taking longer to dry clothes.FRIGIDAIRE MODEL GLER341AS2.
  • 5,911 Answers
If your dryer is STILL heating, but your dryer is showing signs of heavy condensation or longer dry times, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. As the dryer exhausts, moisture from your clothing is circulated with the warm air. If you have any restrictions in the exhaust system, the moisture will collect inside the ducting and drum. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards.
If you do determine you have an internal component problem, the next link can give you some helpful advice on how to troubleshoot a dryer with a no heat problem: http://www.fixya.com/support/r3574266-thorough_dryer_advice http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat If you have any questions, please post back and let me know. I hope you find this information helpful.
Posted on Sep 15, 2010
I have a Frigidaire Dryer model number GLER341AS2. The dryer runs fine, but won't get hot. I pulled the dryer from the wall to see anything obvious. I noticed what I thought at first to be anim
Are you mechanically inclined? You may have several problems. 1st, heating element is most likely burnt out. Then I would check ball and socket assembly that back of drum fits into. Also check felt in front of machine that drum rides on. May need competent service person on this.
Sep 13, 2017 | Frigidaire Electric Dryer
Frigidaire Gallery model Gler341AS2 drum is sagging towards 6 o'clock and causes a gap that snags clothes. What parts need checking to find the cause of this?
seals on front and back, but drum rollers/glides here is a website, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Apr 17, 2011 | Frigidaire GLER341A Electric Dryer
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
Dryer feels hot but takes longer to dry cloths
Clean the entire venting system out. The moister sensor detects any lint build up and puts the heat in the check mode which will produse very little heat until its cleaned out
Jul 08, 2010 | Frigidaire FER311FS Electric Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
When dryer cycle is done elements stay on
One of the switches that controls the heating element has not closed.
Apr 30, 2009 | Frigidaire Dryers
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
Frigidaire GLER341A Electric Dryer Logo
185 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
