Question about Minolta C-550 Camcorder
I have a Minolta Master series -8 80 camcorder which no longer works. I have 8 mm video cassettes and VHS C's that I would like to transfer to CD's or DVD's. Can you help?
The CD player no longer works in my 2005 KIA Sportage
Have you tried different cd's?I f so then the loading tray may be at fault.If you don't want to fix it here is a solution.Buy a cassette adapter with a 3.5 mm connector and use a mp3 player you can transfer your cd collection to your mp3 player via you computer
Oct 17, 2017 | 2005 Kia Sportage
My family videos are stored on the mini VHS tapes. I recently bought a VCR to dvd recorder to transfer them into dvds but now I discover my VHS playpak (that you need to play the mini tapes) is broken....
Maplin Electronics have a motorised VHS-C Cassette adaptor that will enable you to view any camcorder tape on a standard VHS. If that is any help priced around £15.00.
Mar 14, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I want to copy analogue files from my VCR to my Apple Mac using my JVC GZ-MG365 camcorder
You will have to copy the VHS cassette to cd, then using the cd, upload the file to a you tube account or video player.
Mar 04, 2011 | JVC Everio GZ-MG365 HDD Camcorder
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
Many years ago some one told me that you could put your canon video camera 8 mm tapes into a video cassete case and play them on vhs tape machine is this true cause i have many but can not get whats on...
Hello, try matelectronics.com, they have the following product, I think it's what you're looking for: VHS-C CASSETTE ADAPTER(Reference #V-0730)
VHS-C CASSETTE ADAPTER BY PHILIPS PH61300
Jul 20, 2010 | Sony Televison & Video
I have video cassett size 8...I dont have the camcorder to watch it, I need to transfer it the regular DVD or any size...please help...thanks
look online or in some electronic stores for an adapter--the tape fits into a vhs format case and the vhs adapter is inserted into player theirs a vhs play adapter made for just about all compact tape units
Apr 26, 2010 | TDK 8mm MP 120 Minute Premium Camcorder...
Conversion vhs to dvd
I can only offer you 1 option for this case.
In converting the VHS video tape to DVD you can use computer. All you need to have is the VHS player with RCA audio video cables. Then a computer that has video capture card or USB capture card. This will take time but you can just transfer all the copyrighted videos to DVD and to computer data (post to internet)
*Needs realtime transfer VHS to Computer with the prefered resolution option.
*Burn to DVD, it will depends on your DVD drive speed.
Mar 26, 2010 | Video Cameras
Getting footage from a cassette onto a mac
Sorry but the only way to transfer the tape is to be able to play it in a compatible camcorder or player. Then use one of the analog to digital converters "available on the internet" to transfer it to a PC.
Best bet is to ask some friends if they have an old camcorder that will be able to play that video cassette for you.
Sidenote: If the cassette is fairly new it might already be recorded in digital format, in which case you only need a compatible camcorder or player and a USB or Firewire cable to import it into your Mac
Hope this helps, don't forget to vote if the answers you seek are helpful.
Mar 23, 2010 | Canon Optura 50 Mini DV Digital Camcorder
Transferring camcorder tapes to VHS
It depends on what speed these tapes were first recorded on. Maybe the camcorder your trying to use to play them back do not support this tape speed I have seen this in the past. Are these 8-MM or VHS-C tapes.. Also the tapes that were recored, maybe tyhere was something wrong with the tape path and was slightly out of alighnment. I had once a Sony 8-MM camcorder and tapes a lot of stuff and then gave them to someone to watch and they would not play. I tryed the tapes again in my camcorder and they worked great. I got a test tape and tryed it in my camcorder and it turned out the tape path alighnment was off, so i had to rerecord everything I had from one camcorder to DVD so i could fix my camcorder. Good Luck
Mar 26, 2007 | Hitachi VME545 Camcorder
Noise block doring playback of D-VHS tapes
* Do not record program in DVHS mode on an S-VHS cassette. Use of S-VHS cassettes will not allow for maximum performance and may result in head clogging. Use only D-VHS cassettes as recommended in the instruction manual on page 27. * Make sure that the DIGITAL 3-DNR lamp is ON when playing back a cassette recorded in D-VHS mode. If not press DIGITAL 3-DNR so that the DIGITAL 3-DNR indicator illuminates. * When block noise appears on the TV screen, clean the video heads with the DFC-2 D-VHS Head Cleaning Cassette (continue up to 3 minutes total). Please refrain from using any other head cleaning cassettes as drum damage may result.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Video Cameras Logo
413 people viewed this question
Top Minolta Video Cameras Experts
Are you a Minolta Video Camera Expert? Answer questions, earn points and help others
