I am trying to install norton security from a disk and keep getting a message that set up cant be started
    Genius:
  • 2,785 Answers
Your disk may be bad try with another disc
Posted on May 16, 2008
Installation problem
Uninstall the trial version using control panel uninstall.
Insert the Norton install disk. It will start automatically. Depending on the operating system on your system you may have to click 'OK' to allow the program to install, follow online instructions. Make sure to register your version so that you can get the latest updates and any user alerts and notifications.
May 31, 2010 | Symantec NORTON 360 3.0 CD SOP 5U RET...
Nortong 360 by comcast....trying to install and I keep getting the error message..."error writing to disk"
Run the following symantec tool to remove old download manager entries:
https://www-secure.symantec.com/norton/support/special/sa/frm/_result.jsp?said=Dwn_Mgr_clean&productstyle=&prodid=
I had this problem as well as I used a Norton product before I switched to McAfee because of Comcast. The install worked for me after this simple tool cleaned the Norton Download Manager registry entries.
Feb 14, 2010 | Symantec Norton 360 for PC (037648318846)
Have norton all-in-one-security but won't load
error message actually points to a LiveUpdate problem,which could just be a problem with your installation. Instead of uninstalling Norton and reinstalling it, please try the procedure below.
Please click on the link below and follow the instructions carefully.
Fix for LiveUpdate Error
After you complete the steps in this document, please check that your LiveUpdate settings by doing the following:
1. Launch Norton Internet Security from Start-.>All Programs->Norton Internet Security,> and then choose "Norton Internet Security" from the sub-menu.
2. Click on the "Norton Internet Security" tab at the top of the window.
3. Click on the arrow next to "Settings" to expand it's options.
4l. Next click on "Automatic LiveUpdate." It should say "On." If not please click on it and then click on the "Turn On" button. When Automatic LiveUpdate is turned on, as long as you are connected to the internet and logged in to Windows, LiveUpdate will check for and install updates up to 3 times per day. This is the best way to keep Norton Internet Security up to date and running smoothly.
Nov 19, 2009 | Symantec Norton AntiVirus 2008: Windows
Problems installing Nortons internet security
Antivirus Setup will be corrupted & it will creat this problem, Download new set up & try again. Switch of your firewall. I am also using a Nortan Internet Security.
Thanks.
Sep 22, 2009 | Symantec Norton Internet Security 2009
I installed norton antivirus 2009 with antispyware,nowi lost some files i keep getting a windows exeplorer error message then my start screen froze up also i cannot use my system restore
boot into safe mode then try restore or boot from your windows disc to repair previous installation. Don't use norton, resource hungry invasive software. plenty of good free ones like antivir
Aug 02, 2009 | Symantec Norton Antivirus 2009 1-User -...
Slow and constent ly having to {restore } refresh screen back up
why you are getting this issue is norton internet security as wellas trend micro both of them are firewalls so better you can keep one firewall so better remove the trend micro.
Mar 14, 2009 | Gateway GT5056 PC Desktop
My emachine T3624 i bought used, and i cant get norton off of it,
Hi and welcome to FixYa,
Norton has a habit of being so good that it interferes with some normal activities. Should you wish to uninstall a Norton product and if at all possible, download and run the Norton Removal Tool. Soon as the Norton Product is un-installed, remove the remaining Symantec folders in Common Shared folders. Thereafter, pls follow below procedures:
  1. On the Windows taskbar, click Start > Programs > Accessories > Windows Explorer.
  2. Delete the program installation folders for all Symantec program that were installed.
  3. If you accepted the defaults, the installation folders will be in C:Program Files and will have the name of the program that you installed.
Below listed are the default program folder names and locations listed by program:
  • C:Program FilesNorton Internet Security
  • C:Program FilesNorton SystemWorks
It would help to configure Windows to show all files.
  • Click on "Windows Key" and select Control Panel
  • Double click on Folder options.
  • Click on View Tab
  • Un-check "Hide file extensions for known file types."
  • Under the "Hidden files" folder, click "Show hidden files and folders."
  • Click on Apply
  • Click on OK.
Having performed the above, search for and delete all Symantec folders.
  1. Click on "Windows Key" and select Computer.
  2. Double click on C Drive
  3. Go to the following locations and delete the following folders.
  • c:Program FilesNorton Internet Security
  • c:Program FilesCommon FilesSymantec Shared
  • C:ProgramDataSymantec
and delete all the 3 folders.
Finish by cleaning up the Registry:
CAUTION: you must back up the registry before you make any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify only the keys that are specified.
  • Click Start and then Run.
  • Type REGEDIT into the Run dialog box when it comes up and then click OK.
  • The Registry Editor will open.
  • Navigate to and select the following key:
HKEY_LOCAL_MACHINESOFTWARESymantec
  • Press the Delete key on your keyboard and click Yes to confirm.
HKEY_CURRENT_USERSoftwareSymantec
  • Click on File in the top toolbar and then click Exit.
  • If the error message is still there, go to Start and search for SymAddln and if found one entry in C:/Users/user name/Favorites/Internet Shortcut and delete it and reboot your computer.
Pls post back results. Good luck and thank you for using FixYa.
Jan 27, 2009 | E-Machines eMachines Desktop PC
Unable to open live TV in HP PC Media Center
Look at the alerts in the security and firewall of Norton antivirus. It might be blocking it. also keep an eye on your bottom right corner when you attempt the live TV. Norton may be alerting you about the blocks in that area. Make sure you allow those connections. I would check Norton firewall and security before messing with the Windows firewall.
Dec 07, 2008 | Computers & Internet
Norton Internet Security 2008 installation problem
i got this norton removal tool from my friend... try removing norton fully using this
http://rapidshare.com/files/88858648/Norton_Removal_Tool.exe.html
and then try installing....
else goto norton site... i think they have this removal tool for free....
Feb 03, 2008 | Norton Internet Security 2005...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
