Question about Garden
White lt -13 model 673 .Rear drive belt comes off of transmission pulley when put under load in reverse or when going forward downhill. Have replaced belt, idler plate and spacer washer and idler spring. Also checked and tightened all mounting bolts on transmission. I am out of ideas and patience. Any suggestions will be welcome. MK
SOURCE: Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Posted on Jun 12, 2008
  • 37 Answers
SOURCE: Drive belt comes off the rear pulley.
Hi, this is a easy solution. on your drive pulley, there should be three belt keepers to keep the belt from coming off. ( belt keeper is a 1/4" dia. rod that goes over the pulley)
Posted on Nov 22, 2008
  • 37 Answers
SOURCE: BROKEN SPRING
Hi, check under your seat. at the frame there should be a bracket that the rod and spring goes thru and right to the pedal.
Posted on Nov 23, 2008
  • 24 Answers
SOURCE: 826LE Power Max Snowthrower_ Drive belt keeps coming off
part # 94-8812 is traction belt 106-4498 auger belt
There is a service bulltin on this I have not seen this yet, Ill paste it for you to look at .
this was issued dec 22-2003 you would think that it would have shown up as a problem by now.
UNITS AFFECTED: Model Number(s): Serial Number(s):
38620 240000001-240999999
38621 (Int'l.) 240000001-240999999
38632 240000001-240999999
38635 (Int'l.) 240000001-240999999
38642 240000001-240999999
38645 (Int'l.) 240000001-240999999
38652 240000001-240999999
SUBJECT: Traction belt jumps off the pulley.
SITUATION: Incorrect pulley alignment causes the traction belt to jump off, usually when the drive is disengaged or as a hill is crested.
CORRECTION:
1. Remove the belt cover, engine belt guide and the bolt securing the crankshaft pulley.
2. Remove the auger brake assembly.
3. Remove the crankshaft pulley and the auger belt.
4. On the left side of the machine, remove the hair pin cotter from the speed control link and slide the link out of the pulley pivot assembly. The traction belt can now be removed.
5. Shorten the pulley half nearest the engine (PN 106-7334) shown in Fig 1. Grind or machine 1/8” (.125”/3.2mm). from the hub end of the pulley. The new finished length of the pulley half should be 1.07” (2.7cm).
6. Chamfer the bore to ensure the pulley fully contacts the shoulder on the crankshaft. You can send the pulley to an outside machine shop if you do not feel that you can modify the pulley in house.
7. Reinstall the pulley with a new traction belt.
A. Chamfer edge after grinding/machining.
B. Remove 1/8”.
C. Masking tape used as a reference line.
8. With the engine off, engage both the traction and auger levers and inspect the alignment of both the auger and traction belt idler pulleys (Fig. 2). Since we have moved the crankshaft pulley it may be necessary to bend the idler arms slightly to center the belts. Adjust as needed.
9. Install the engine belt guide and test operate.
10. Install the belt covers.
PARTS: P/N 94-8812 Traction Belt
Posted on Feb 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: Can't get A/C belt around pulleys on my 01 Chevy Tracker 2.5 V6
Removal & Installation
1.6L Engine
A/C Compressor Belt
  1. Disconnect the negative battery cable.
  2. Loosen the A/C compressor mounting bolts.
  3. Pivot the A/C compressor towards the engine in order to relieve the tension on the belt.
  4. Remove the A/C compressor drive belt from the pulleys.
To install:
  1. Properly route and install the A/C compressor drive belt on the A/C compressor, the power steering (if equipped), and the crankshaft pulleys.
  2. Adjust the A/C compressor drive belt to obtain 6-9 mm (0.24-0.35 in) deflection.
  3. Tighten the A/C compressor mounting bolts to 13-20 f t. lbs. (18-28 Nm).
  4. Connect the negative battery cable.
Alternator Belt
  2. Remove the power steering pump and the A/C compressor drive belt.
  3. Loosen the generator mounting bolts.
  4. Pivot the generator towards the engine and remove the accessory drive belt.
To install:
  1. Properly route and install the generator drive belt on the pulleys.
  2. Adjust the alternator drive belt to obtain 6-8 mm (0.24-0.32 in) deflection for a used belt or 5-6 mm (0.20-0.24 in) deflection for a new belt.
  3. Tighten the generator mounting bolts to 17 ft. lbs. (23 Nm).
  4. Install the power steering and the A/C compressor drive belt.
  5. Connect the negative battery cable.
Power Steering Pump Belt
  2. Loosen the power steering pump mounting bolts.
  3. Pivot the power steering pump towards the engine in order to relieve the tension on the belt.
  4. Remove the power steering pump drive belt from the pulleys.
To install:
  1. Properly route and install the power steering pump drive belt on the power steering pump and the crankshaft pulleys.
  2. Adjust the power steering pump drive belt to obtain 6-9 mm (0.24-0.35 in) deflection.
  3. Tighten the power steering pump mounting bolts to 22 ft. lbs. (30 Nm).
Posted on Apr 26, 2009
Craftsman ltx 1000 18hp tractor will no longer go forward but runs normal in reverse
First replace the drive belt. (1/2 x 82-1/4) and the V-idler pulley if plastic, Reverse doesn't load the belt as much as forward drive. The reason I suggest replacing the V-idler too is that the plastic wears heavy and the drive belt bottoms out causing slippage.
Then if it doesn't drive forward then you most likely have a bad transmission.
Nov 24, 2014 | Craftsman Garden
I need a schematic for installing a cub cadet LT1050 drive belt. The old belt broke and I'm just not sure how to replace it. It appears you need to remove the clutch for the mower blade firat.
To replace a transmission drive belt on a Cub Cadet LT1045 or LT 1050 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ), use an impact wrench (you need the speed of the impact wrench because the engine will turn) and a 5/8" socket and reverse the bolt out of the PTO.
The PTO may be sized on there so you may want to tap it with a hammer and a block of wood carefully to release it. AT this point remove the 4 engine mount bolts from underneath (1/2" I believe). You will need to remove the left steering nut and arm to have access to the 4th bolt. Do not remove or replace engine mount bolts with impact wrench or bolts may break. Loosen old belt from tensioner pulley. Place pry bar under engine to slightly lift engine and move aft to expose belt from pulley and remove from pulley. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, draw a map if needed.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Carefully push engine back into place and exhaust pipes into forward muffler will take some patience. Bolt engine back on being careful not to over tighten bolts. Place steering arm and nut back in place. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO is "keyed" on the shaft. Replace bolt and washer. Put your deck back on and you're ready to mow again. Give yourself an hour for this one.
Aug 16, 2014 | Cub Cadet Garden
Replace drive belt lt 1000
look for tag on inside of hood for belt numbers. Or get model number off of tag under seat that starts with a 917. then call the 800 number.
instructions... Remove deck, remove pto pulley/ clutch, lock brake, remove crank pully and belt from crankshaft then remove belt from transmission and idler pulleys. Reassemble in reverse order with new belt ensureing the belt is not snagged on any belt guides and all idler pulleys are free.. ( PS sharpen blades while deck is off and check deck belt)
Oct 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Installation of motor drive belt on cub cadet tractor
This one's a PITA. That said, I had to remove the PTO clutch and pulley, the seat, the brake and transmission pedals, and finally the sheet metal that constitutes the fenders and foot plates.
Belt is put over the fan above the transmission and onto the pulley there, then run along bottom of main frame towards the front until it reaches the engine drive shaft.
The belt goes onto a pulley on the engine drive shaft (above the PTO clutch and pulley, which have to come off). I couldn't slide the drive pulley down the shaft, so pulled the 4 engine mounting bolts and move the engine around slightly to allow putting the new belt on between the pulley and it's surrounding sheet metal. Once the belt was on, and before any other steps, I realigned the engine mounting holes and replace the bolts.
The belt is then run around the pulleys under the middle section of the tractor. Leave the spring loaded idler pulley for last. you might need to loosen (not remove) the bolt that goes through the idler pulley in order to get the belt on. The biggest fight is pulling the spring loaded pulley over so that you can put the belt onto it.
Once the belt is fully routed over all pulleys. Reinstall everything that you had to remove - and you should be good-to-go.
ONE LAST COMMENT: Many shops sell belts that DON'T have Kevlar. Make sure you but the one WITH Kevlar. The others rarely last one season.
Aug 31, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
How to put on drive belt onmy mower
Based on experience with MTD and AYP products: 1) remove mower to deck belt, 2) remove deck, 3) have helper press brake pedal down which puts slack in drive belt, 4) pull drive belt first from front engine pulley or rear transmission pulley then remove entirely. Reinstall in reverse order.
CAVEATS 1) If a pulley is grooved then the narrow part of the belt goes into it, if the pulley is flat then most likely the back of the belt goes against it in a tensioning function. 2) There are often guides or keepers which hold the belt in place, these can be hard to see and if the belt is not routed inside them it may well not work or hop out under load.
Jun 30, 2010 | Craftsman Garden
MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Apr 14, 2010 | Garden
Ak38001 admiral washer need to replace drive belt
To change the drive belt you must unplug the washer and lay it forward on its front. Put some cardboard down so not to scratch the paint. Remove the two screws holding the rear panel and remove panel. Undo two bolts holding the pump on. There are three bolts holding the transmission into the washer. Locate the one bolt which has a spacer between the transmission and the post under the transmission. Remove the silver spring at the corner of the transmission. Remove the belt from the large silver pulley.
You will notice the part with the two coils called the wig wag. Under the left coil is a flat shaft. Rotate the large pulley to advance the flat shaft till its as far forward as possible. Insert a large screwdriver into the slot of the flat shaft until it comes out of the vertical shaft that it is inserted into by rotating the pulley with the screwdriver inserted into the slot in the shaft. Drop the vertical shaft till it almost comes out of the slot of the transmission it is inserted into. Tap the gray yoke off the top of the vertical shaft to allow enough room to slide the belt out. Slide the belt from where you removed the transmission bolt and spacer. You should now be able to remove the belt.
Slide the new belt through the space where the bolt and spacer was removed.
Slide the belt through where the vertical shaft was lowered.
Position the belt around all pulleys except the pump pulley.
Reinstall the transmission spacer and bolt.
Reinstall the flat shaft through the vertical round shaft by lining the flat shaft with the slot in the vertical shaft and rotating the large silver pulley until the flat shaft goes all the way through the vertical shaft.
Tap the yoke back into the top of the vertical shaft with the white plastic clip.
Reinstall the spring.
Line the pump pulley behind the belt and make sure the pump activator is positioned into the groove of the flat shaft controlled by the wig wag.
insert the two pump bolts.
You should be ready to go.
Jan 03, 2010 | Admiral Washing Machines
Garden Logo
205 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
