Question about HP Officejet 5610 All-In-One InkJet Printer
Printer says '' error- offline" everything is hooked up worked fine yesterday and last 3 years
  • 30 Answers
Is the correct driver installed? also is it plugged in to the same usb port? Visit the manufactuers website and update youre rivers but do it while the printer is unplugged then plug it in
Posted on Sep 15, 2010
Error message that my IP90 Canon is offline.
Check that you haven't accidentally changed it setup to being off line, you will find this in the devices section of the control panel. If that doesn't work I suggest you re-install the printer software using the setup disk that should have come with the printer. Hope this helps.
Dec 30, 2012 | Canon PIXMA iP90 Mobile Printer
Printer offline
Hi
Try disconnecting the printer completely from power and from the PC.
Leave it as such for one hour.
Connect the printer again.
Check the connections and make sure its well connected.
Feb 24, 2012 | Brother MFC 7840W Printer
My hp c8180 printer is showing to be offline. I have uninstalled it and reinstalled driver. It worked fine when I printed the test page, then it went offline again. BTW -- it is hooked up to a router....
Go into the network setup on the printer and set it up as a static IP address. If you go into the network settings on the printer and select the manual configuration. Then go to your computer and hit Start > Run > and type CMD and hit enter. This will bring up command prompt. Type ipconfig into the command prompt and hit enter. This will show you the ip address your computer is using. It is most likely something like 192.168.1.1. Go on your printer and make the first three sets of digits the same, and change the last digit to something like .25. Then enter everything else in the printer the same as it is on your computer. This should alleviate any problems your printer has.
Mar 03, 2011 | HP Photosmart C8180 All-in-One InkJet...
Our hp lj doesn't work anymore. After restart it says "Scan Error 5" or "Scan error8". This morning I managed to send a last fax but after this it stopped working. We had problems with printing those last...
this printer is experiencing what is known as a formatter/scanner assembly failure, hp has a service note issued to service printer up to 2 years after the purchase date.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp. 1800-334-5144 in order for them to create a case under the service note and have the printer serviced. Both the scanner assembly and formatter board need to be replaced.
Al
Eliteprintersolutions@gmail.com
Mar 24, 2010 | HP Laserjet M2727nf Multifunction Printer
My photosmart B209 was just hooked up and connected yesterday. I was able to print wirelessly. Today, the printer says that it is connected, but offline. How do I put it online?
A wide range of problems are addressed in the following solution from HP. From what you have stated, try Solution 2, Step 3 - "Determine whether the printer is paused or offline."
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01893322&cc=us&lc=en&dlc=en&product=3777182
Dec 06, 2009 | HP PHOTOSMART PLUS B209A All-In-One...
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
Cannot print to network printer
Is this printer installed on a server and shared over a network? Or is it installed independently on each workstation?
If it's on a server, printing could be "paused", or set to "use offline" Go to the "printers and Faxes" dialog box, and 'right click" on the printer icon, is there an option to either "resume printing", or "use printer ON line"? If so, select this option.
If it's not on a server then it would be extremely unlikely that this condition would happen on all workstations
Other than that make sure that the Subnet mask is set correctly on the printer.
If that doesn't work....it's probably time to try re-installing the driver.
May 13, 2009 | Kyocera Copystar CS-1820 Black and White...
HP Officejet 4315 All-in-One went offline
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Officejet 4315 All-in-One Printer
OFFLINE PROBLEM
disconnect USB, go to RUN and type in services.msc and then find print spool and right click, then choose restart .plug in usb
Mar 02, 2008 | HP PhotoSmart C4280 Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
210 people viewed this question
Seeker5211
Seeker5211
