Question about Dometic RM2620 Refrigerator
We bought a motor home witha 2604 in it. It isn't cooling when plugged in and when I opened it to check it a very strong, powerful chemical odor came out of it. It made my eyes water and burn. What is going on?
  • 2,299 Answers
Sounds like the refrigerant is leaking into the inside of the refrigerator. I would suggest not leaving it plugged in and take it to an appliance repair shop, or get rid of it. This refrigerant is harmful to breath and is not good for the atmosphere.
Posted on Sep 15, 2010
How do I remove a chemical smell from my freezer and refrigerator?
From my experience smell from freezer is available to remove with lemon water (1 lemon juice + 1 liter water). wipe with a soft rag. Perfectly if freezer is not plugged to 220V power and doors are open 1-3 days.
Sep 24, 2015 | Refrigerators
Sears Kenmore refrigerator odor in freezer?
A quick phone call to Sears or a local appliance service center may be in order. Since the evaporator that cools everything is located inside or very near the back of the freezer and the freezer has the lowest air circulation of the entire refrigerator, I would suspect a small refrigerant leak. Many refrigerants have strong odorizing chemicals added for just this purpose. Natural gas for heating has these same chemicals to warn us of the danger if a leak occurs. If it is a leak it's not dangerous, but very soon you will come home to a warm fridge and thawed food. Prior to that you'll hear the fridge running constantly as it tries to maintain the proper temp.
Mar 09, 2013 | Refrigerators
2004 Taurus has strong chemical smell
The tank is loosing coolant because there is a leak somewhere in the cooling system. I would have the system pressure tested to verify there is a leak. Sense there is a odor in the car and the coolant is low ..I would suspect the heater core is leaking. A pressure test will help locate the leak in the system.
Nov 19, 2012 | 2004 Ford Taurus
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Odor in my home
There may be mildew on the condensor (the big radiator inside the attic) and/or the water drip tray underneath it may not be fully draining causing the odor.
Your senses get "used" to the odor. Your brain will mask it so that you will be able to sense other odors.
Replace the return air filter more often. clean the airway taht the filter covers. Spray Lysol will help temporarily.
You must check the condensor & water drip pan.
Sep 28, 2009 | Heating & Cooling
We just bought a new Tappan gas range. We turned the oven on to use it and there is a strong, disgusting chemical odor, so strong I was nauseaous all day. Is this normal?
no this is not normal. you need to check the gas lines and make sure there are no leaks. the insure that all the plastic and tape has been removed,if need be set it up for service
Sep 27, 2009 | Tappan TGF320 Gas Kitchen Range
Chemical odor in freezer
can you verify the odor. Does the odor smell like burnt wire insulation or of that of burnt meat?
Jul 05, 2009 | Kenmore Freezers
Chemical odors from printer
I think the odor is from Fuser Unit and will not last for more days.
Apr 11, 2009 | Samsung CLP 315 Laser Printer
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Dometic RM2620 Refrigerator Logo
42 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
