Question about Nintendo DS Lite Console
My ds turns on then off right away hat do i do
I love wearing hats but I have quite big, thick glasses and I usually have a problem getting the hat to balance right. What can I do about it?
If you wear glasses, turn the brim up on your hat or go for a hat where the brim turns up on one side. Avoid flower-pot style hats as they can be very unflattering when worn with glasses.
Mar 04, 2013 | Clothing Accessories
My prob
go to a place like gamestop or game trader and have them look at it
May 10, 2010 | Nintendo DS Lite Console
When i need to blow into the ds microphone to dry off littest pet shop, nothing happens
It may be possable that the microphone is broken. Did you try cleaning it off? Did you try blowing on it a lot so the dust inside the ds(i) comes off (out)? If none of these work, Just send in you're ds to nintendo, They can fix it. Don't buy a new ds, calling nintendo is cheaper.
I hope this helps!
Jan 31, 2010 | Nintendo DS Lite Console
I have a black ds lite and i accently dropped it in my pool and it turns on and it dosent show the picture and it used to show lines.
When any electronic is dropped, you must take the battery out right away. Also, you should put the device and the battery in a jar of rice because the rice absorbs any moisture quickly. Your DS might be water-logged. Meaning, the water has corroded the wires inside and made it difficult or impossible for electricity to flow. However, because it DOES turn on, the problem could be with the screen only. DS replacement screens are available on ebay, but require self-installation. Buying a screen will not necessarily fix your DS.
If your DS is still under warranty or if you have home owner's insurance, I would call Nintendo and tell them that your DS is defective and stopped working and that you would like to send it in and get it replaced. Home owner's insurance may or may not cover your DS, it depends on your coverage and deductable. Hope this helps.
Oct 26, 2009 | Nintendo DS Lite Console
Nintendo DS Lite games won't work!
my son's DS had the same problem this week. With the DS turned off, ,I pushed the game in and held it right down while turning the DS on. The game registered and I let go of the game and it clicked in to place. The next time I tried the game it registered straight away. Good luck!
Jul 09, 2009 | Nintendo DS Lite
Nintendo DS Lite power adaptor disconnection problem
There is a small latch on the connector that may be stuck. Try this. Turn the DS Lite upside down with the charger plug facing away from you. Press down the on the plug gently with your right thumb and with your left hand pull the connect away from the socket. FYI this should be a simple fit! Make sure the connector was not jammed in upside down to start with. It has a clear six sided shape to it!
Dec 23, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
275 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
